Four mass-spring-damper system State Space Model
EricHong
Please, help. The question is stated inside the file.
Thanks in advance,
Eric
AlanStevens
(To:EricHong)
You're asking Mathcad to find an analytical solution to an 8'th order polynomial! Can't be done above 4th order! Stick with numerical solutions.
Alan
6 REPLIES 6
AlanStevens
(To:EricHong)
Alan
wayne
(To:EricHong)
Eric
The last equation has kc, but should be kd
Mathcad has functions for eigenvalues (eignevals) and it will provide numerical results ( I tried it on your corrected matrix), but not symbolic, as Alan indicates
Even if you could get one, it would probably be so long as to be unuseable.
EricHong
(To:wayne)
Thanks. It's kc alright. There's no kd. kc is the spring between mc and md.
After all, Alan is right.
Thank you all,
Eric
wayne
(To:EricHong)
You have 4 masses connected with 3 springs? After lookiing at the matrix again, it's not clear to me what the arrangement would be? Just for my own curisoty, could you pass along?
Wayne
EricHong
(To:wayne)
see the attached.
note that the system is not ground at any point. the dampers are shown to ground, but you can think of them as sliding masses on a viscous surface. due to a unique nature of the system, damping isn't a funciton of delta velocity between masses.
thanks,
eric
wayne
(To:EricHong)
Eric,
Interesting problem, thanks for the reply.
Wayne
