Generate a delimited ASCII file with a data spacer and read it with Excel
PatriceBujard-d
Dear Mathcad Guru's,
I am using the function
array = augment(vect1, vect2, vect3,..) n vectors in total. Each vector has m rows
to create an array of data of m rows and n columns
The data can be positive or negative
Then I write the array with the command
WRITEPRN(file_name) = array
When I want to read the data with Excel, I open it with the Text Import Wizard, using the delimited option and space (or other) in order to read the various columns.
It happens very often that the text Import Wizard doesn't recognise correctly the columns.
One way to avoid this issue would be to introduce a delimitation (like space, ; or else) between the columns.
I need to be able to read the data with Excel, after I generated delimited (?) ASCII file with mathcad
I have also tried
WRITEFILE(file_name,"Excel"):=array
but it seems not to work ! What did I wrong there
Does anyone knows how to solve this issue ?
Thank you for your help
Go to "Tools", "Worksheet Options", "Built-in Variables" tab, and increase the column width. That might fix it.
5 REPLIES 5
Can you please plot an example of the data?
Mike
http://communities.ptc.com/servlet/JiveServlet/showImage/2-149416-2532/bar_anim.gif
OK, I have joined an example in the form of picture in a ppt file.
I put a picture of waht we can read in a mathcad file and whyt i am getting after importing it in Excel with the Text Import Wizard.
You can see how the Text Import Wizard cannot really identify the data (especially with a minus sign)
Thank you for you help
I have also tried
Because there's no such function
I have also tried
Mr. Jackson had the answer, I'm merely providing an example
