Hi All,
Could you please have a look at the attached file and let me know why I am getting different answers?
if the number in question is an input you I get the answer I am looking for, if the output is a result form say interpolation I will get wrong answer!!!
Why, this is happening, and how to overcome it?
H
This is an effect which you have to take in account when you are working with float numbers. Never compare float numbers for equality.
Its a roundoff effect. While the interpolated value R should be exactly 17.85 its actually slightly smaller - approx. -3.5*10^(-15). Evaluate R-Rd to see it yourself.
WE
Hellow,
How can I overcome this issue then? Any advise
On the "Calculation" tab, select "Calculation Options" and "Approximate Equality".
Thank you
