Getting undefined error for function
JM_10241707
8-Gravel
Somehow I am not getting the function to work in 15. Can someone help on this.
(To:JM_10241707)
You define a function etaB, but try to evaluate a function etaT which is nowhere defined?
Furthermore your range variables i and j don't make much sense in the function definition. What did you expect them to achieve?
Defining lambda:=5 is useless because lambda is the (formal) function argument. The value for lambda has to be provided as argument when you call your function.
Did you look for something like this:
(To:JM_10241707)
