Given/Find
ELSID
Given/Find
Did not want to hijack the other thread.
From http://collab.mathsoft.com/~Mathcad2000/read?129868,15
jmG,
A) there are scripts (sliders) ... Just wanted to bring it up from your comment on an other post :).
B) have you checked to make sure there are no errors on your version of Mathcad?
As an example: 3. The generalised seeded root scanner for inversing a function
You define the npts in an array. I understand what you did, but it errors in Mathcad 14 M030
8 REPLIES 8
ELSID
(To:ptc-1368288)
>jmG
Now that was RUDE!<<br> ==> NOT at all, the exact answer, point by point.
How could I be rude, helping so much and so largely ?
Many collabs tend to fly away of the question, not me: too old .
You are pointing out that 14 does not take all the constructs of the previous versions.
I bet there is in the work sheet another discretizer doing same.
How do you appreciate or dislike so many 14 users didn't come back ?
OK, it was mentioned long time ago this construct does not work in 14.
Is that the only thing that does not work ?
Will look at it tonight. Nobody even replied if 14 has a built-in discretizer.
JmG
Try that discretizer.
jmG
It took you this long to notice that jmG is typically rude? I'm surprised.
__________________
� � � � Tom Gutman
ELSID
(To:TomGutman)
No, I've said it before. I just wanted to get my point across that some "power users" have incorporated scripting (sliders) into the sheets that are posted in this forum. To jmG's credit, there are a lot of sheets that are worth learning from, not everyone uses Version 11.2a.
>uses Version 11.2a.
______________________________
At least, you know that my work sheets have only sliders. Other collabs have all sorts of them, most of the time not working. I want to correct you: I'm the only collab using sliders. You know why ? There are as many lazy Mathcaders than there are in lazy peoples in the society, if you don't chew for them they won't bite.
Does the new discretizer work ?
Please ask any question in that work sheet.
Will be OFF between Dec 01 ... Jan 15
jmG
This kind of assignaments are based on a bug from some mathcad version. To make this working into Mathcad 14 there are an option somewhere under Preferences or worksheet options, but can't remember where.
Regards. Alvaro.
