My Prime 2 (student academic version) had stopped working. Its on my computer which is the backup now used predominantly. It had a downloaded Windchill ProductPoint Client Manager, then reloaded Prime 2, and had the latest license email dat file placed in the same folder as the drive the program is installed in, and also tired with the older license dat file. Failed. I get an error message each time that changes its number its 'An Unhandled exception occured on the dispatcher thread. See C:\ProgramData\PTC\Mathcad Prime\Logs\Mathcad Prime_Exception_20160914_214823.log. Academic license so please help. I need to get it running asap. If you are with PTC please help also I had spent hours with different configurations.
Please submit your request in "Academic Support Request" form: Academic Case Logger
Run the license wizard to point Mathcad to the license file. Simply putting the license file in the Mathcad folder will not work.
The Prime 2 program does not open it starts to where its front page comes on then there is the error message then it closes.
If I can get the program up then I can go to Options and then point to the file, cant get there.
So is the error message saying something related to pointing to the file or there is more?
If you can assist thanks. I had put in a request to Academic Support.
Try to repair the installation of Prime 2.
Did the repair in control panel at software page right clicked and selected repair. No results.
Karl,
1. If you have installed a Windchill component, then try renaming (such as "WPP_Add"), or delete a folder "WPP_AddOn". This folder should be located on the following path: "C:\Program Files\PTC\Mathcad\Mathcad Prime 2.0".
2. To start the license manager run the application "LicenseWizard.exe" which is located in the same path: "C:\Program Files\PTC\Mathcad\Mathcad Prime 2.0".
Hello Valdimir,
I could not find the folder for Windchill Product Point Client Manager.
In addition Prime 3 is working and is on the same drive. Could there be a conflict here so do I need to remove Prime 3.0?
So far no luck I had reinstalled several times, and run and completed the License Wizard in the Prime 2 folder. Then started Prime 2.0 and got the same error message.
Another question. Currently opening mcdx files created in Prime 2, do not open using Prime 3. Is there a way to bypass this.
Hi Karl,
1. No, there should be no conflict. At me normally work on Windows 8.1 both versions of Prime - 2.0, 3.0, 3.1.
2. And what happens when you open this file in 3.0 version, can you attach Prime 2.0 worksheet?
Hi VladmirN,
I cannot attach prime 2 files to prime 3.
By this I mean I open the prime 2 filed while in prime 3. Unless there is something I Need to do in prime 3 to open the prime 2 files let me know.
I mean attach Mathcad Prime 2.0 worksheet to the message here. The older version Prime 3.0 should normally open files created in a previous versions Prime 2.0, 1.0 (but it does not work the other way around). And what happens when you try to open a file?
Go to All Apps, PTC Mathcad, run the PTC Mathcad License Wizard. It runs independently of Prime.
Hi. I know that could be some frustrating, but do you try to read what is inside the log file? Can found some interesting thing there?
Best regards.
Alvaro.
Hello Alvaro,
I do not see a Log file in the C:/Mathcad/Prime2.0 folder.
Usually the log file is opened using notepad, not in my folder.
Cheers and Thanks,
Karl Bogha.
All your Mathcad Prime log files are located in the following path: C:\ProgramData\PTC\Mathcad Prime\Logs
Hello VladmirN,
I can't find Program Data in the C drive nor in Windows.
However I had seen this folder during installation each time. It appears during the installation process.
I looked for it in the Windows/User folder and there to none.
So for now how do I get to Logs?
C:\ProgramData directory is hidden by default. See following picture.
Simply copy and paste C:\ProgramData into Windows Explorer address bar to see the contents of this directory.
MH
Hello All,
Thanks Martin Hanak I got to the ProgramData/Log folder and got the latest file opened and saved it.
Also in the same ProgramData/License folder I have come to MathcadLicense.10.dat. I keep trying with reinstall or repair and it requires a new license so I had managed to get 10 such files plus the one file without a number MathcadLicense.dat.
File location : C:\ProgramData\PTC\Mathcad Prime\Logs\Mathcad Prime_Exception_20160923_215809.log.
Latest log file copy pasted below.
Build Number : 2012.02.17.RC06
System Culture : en-US; Current UI Culture : en-US
Architecture: x86
Exception data:
System.Object:
System.Windows.Markup.XamlParseException: Provide value on 'System.Windows.Baml2006.TypeConverterMarkupExtension' threw an exception. ---> System.Configuration.ConfigurationErrorsException: Configuration system failed to initialize ---> System.Configuration.ConfigurationErrorsException: Root element is missing. (C:\Users\Karljeet\AppData\Local\PTC\MathcadPrime.exe_Url_ekf0ceoyb5f0c5jtvxm1owuocajql20q\2.0.4430.15358\user.config) ---> System.Xml.XmlException: Root element is missing.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.ParseDocumentContent()
at System.Xml.XmlTextReaderImpl.Read()
at System.Xml.XmlTextReader.Read()
at System.Configuration.XmlUtil..ctor(Stream stream, String name, Boolean readToFirstElement, ConfigurationSchemaErrors schemaErrors)
at System.Configuration.BaseConfigurationRecord.InitConfigFromFile()
--- End of inner exception stack trace ---
at System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal)
at System.Configuration.BaseConfigurationRecord.ThrowIfParseErrors(ConfigurationSchemaErrors schemaErrors)
at System.Configuration.BaseConfigurationRecord.ThrowIfInitErrors()
at System.Configuration.ClientConfigurationSystem.OnConfigRemoved(Object sender, InternalConfigEventArgs e)
at System.Configuration.ConfigurationManager.PrepareConfigSystem()
at System.Configuration.ConfigurationManager.GetSection(String sectionName)
at System.Configuration.PrivilegedConfigurationManager.GetSection(String sectionName)
at System.Net.Configuration.WebRequestModulesSectionInternal.GetSection()
at System.Net.WebRequest.get_PrefixList()
at System.Net.WebRequest.Create(Uri requestUri, Boolean useUriBase)
at System.Net.WebRequest.Create(Uri requestUri)
at MS.Internal.WpfWebRequestHelper.CreateRequest(Uri uri)
at System.Windows.Media.ColorContext.Initialize(Uri profileUri, Boolean isStandardProfileUriNotFromUser)
at System.Windows.Media.ColorContext..ctor(PixelFormat pixelFormat)
at System.Windows.Media.Imaging.BitmapSource.CreateCachedBitmap(BitmapFrame frame, BitmapSourceSafeMILHandle wicSource, BitmapCreateOptions createOptions, BitmapCacheOption cacheOption, BitmapPalette palette)
at System.Windows.Media.Imaging.BitmapFrameDecode.FinalizeCreation()
at System.Windows.Media.Imaging.BitmapFrameDecode..ctor(Int32 frameNumber, BitmapCreateOptions createOptions, BitmapCacheOption cacheOption, BitmapDecoder decoder)
at System.Windows.Media.Imaging.BitmapDecoder.SetupFrames(BitmapDecoder decoder, ReadOnlyCollection`1 frames)
at System.Windows.Media.Imaging.BitmapDecoder.get_Frames()
at System.Windows.Media.Imaging.BitmapFrame.CreateFromUriOrStream(Uri baseUri, Uri uri, Stream stream, BitmapCreateOptions createOptions, BitmapCacheOption cacheOption, RequestCachePolicy uriCachePolicy)
at System.Windows.Media.ImageSourceConverter.ConvertFrom(ITypeDescriptorContext context, CultureInfo culture, Object value)
at System.Windows.Baml2006.TypeConverterMarkupExtension.ProvideValue(IServiceProvider serviceProvider)
at MS.Internal.Xaml.Runtime.ClrObjectRuntime.CallProvideValue(MarkupExtension me, IServiceProvider serviceProvider)
at System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri)
at System.Windows.Markup.WpfXamlLoader.LoadBaml(XamlReader xamlReader, Boolean skipJournaledProperties, Object rootObject, XamlAccessLevel accessLevel, Uri baseUri)
at System.Windows.Markup.XamlReader.LoadBaml(Stream stream, ParserContext parserContext, Object parent, Boolean closeStream)
at System.Windows.Application.LoadComponent(Object component, Uri resourceLocator)
at Spirit.ExtendedCommands.InitializeComponent()
at Spirit.SpiritMainWindow..ctor()
at Spirit.App.PrimeStartup(Object sender, StartupEventArgs e)
at System.Windows.Application.OnStartup(StartupEventArgs e)
at System.Windows.Application.<.ctor>b__1(Object unused)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
Mathcad Prime started at:
09:57:58 09/23/2016
Output of systeminfo.exe utility:
Host Name: KARLDHALIWAL
OS Name: Microsoft Windows 8.1
OS Version: 6.3.9600 N/A Build 9600
OS Manufacturer: Microsoft Corporation
OS Configuration: Standalone Workstation
OS Build Type: Multiprocessor Free
Registered Owner: Karljeet
Registered Organization: Hewlett-Packard
Product ID: 00258-61278-56179-AAOEM
Original Install Date: 28/06/2014, 2:13:06 a.m.
System Boot Time: 23/09/2016, 1:28:06 a.m.
System Manufacturer: Hewlett-Packard
System Model: HP Pavilion 15 Notebook PC
System Type: x64-based PC
Processor(s): 1 Processor(s) Installed.
[01]: AMD64 Family 22 Model 0 Stepping 1 AuthenticAMD ~1500 Mhz
BIOS Version: Insyde F.15, 3/06/2014
Windows Directory: C:\Windows
System Directory: C:\Windows\system32
Boot Device: \Device\HarddiskVolume2
System Locale: en-nz;English (New Zealand)
Input Locale: en-us;English (United States)
Time Zone: (UTC+12:00) Auckland, Wellington
Total Physical Memory: 3,554 MB
Available Physical Memory: 1,931 MB
Virtual Memory: Max Size: 6,371 MB
Virtual Memory: Available: 3,546 MB
Virtual Memory: In Use: 2,825 MB
Page File Location(s): C:\pagefile.sys
Domain: WORKGROUP
Logon Server: \\MicrosoftAccount
Hotfix(s): 298 Hotfix(s) Installed.
[01]: KB2899189_Microsoft-Windows-CameraCodec-Package
[02]: KB2868626
[03]: KB2883200
[04]: KB2887595
[05]: KB2894852
[06]: KB2894856
[07]: KB2903939
[08]: KB2911106
[09]: KB2919355
[10]: KB2919394
[11]: KB2920189
[12]: KB2928680
[13]: KB2934520
[14]: KB2954879
[15]: KB2955164
[16]: KB2959626
[17]: KB2961908
[18]: KB2962409
[19]: KB2962806
[20]: KB2965142
[21]: KB2965500
[22]: KB2966826
[23]: KB2966828
[24]: KB2967917
[25]: KB2968296
[26]: KB2969339
[27]: KB2971203
[28]: KB2972103
[29]: KB2972213
[30]: KB2973114
[31]: KB2975061
[32]: KB2975719
[33]: KB2976627
[34]: KB2976978
[35]: KB2977629
[36]: KB2977765
[37]: KB2978122
[38]: KB2978126
[39]: KB2984006
[40]: KB2987107
[41]: KB2989647
[42]: KB2989930
[43]: KB2990967
[44]: KB2993100
[45]: KB2994290
[46]: KB2995004
[47]: KB2995388
[48]: KB2996799
[49]: KB2998174
[50]: KB2999226
[51]: KB3000850
[52]: KB3003057
[53]: KB3003667
[54]: KB3004361
[55]: KB3004365
[56]: KB3004545
[57]: KB3008923
[58]: KB3012199
[59]: KB3012235
[60]: KB3012702
[61]: KB3013172
[62]: KB3013531
[63]: KB3013538
[64]: KB3013769
[65]: KB3013791
[66]: KB3013816
[67]: KB3014442
[68]: KB3015696
[69]: KB3018133
[70]: KB3019978
[71]: KB3020338
[72]: KB3020370
[73]: KB3021910
[74]: KB3022777
[75]: KB3023219
[76]: KB3023222
[77]: KB3024751
[78]: KB3024755
[79]: KB3029432
[80]: KB3029603
[81]: KB3029606
[82]: KB3030377
[83]: KB3030947
[84]: KB3033446
[85]: KB3035126
[86]: KB3035583
[87]: KB3036612
[88]: KB3037576
[89]: KB3037579
[90]: KB3037924
[91]: KB3038002
[92]: KB3038936
[93]: KB3041857
[94]: KB3042085
[95]: KB3042553
[96]: KB3044374
[97]: KB3044673
[98]: KB3045634
[99]: KB3045685
[100]: KB3045717
[101]: KB3045719
[102]: KB3045755
[103]: KB3045992
[104]: KB3045999
[105]: KB3046017
[106]: KB3046480
[107]: KB3046737
[108]: KB3047254
[109]: KB3048043
[110]: KB3052480
[111]: KB3053863
[112]: KB3053946
[113]: KB3054169
[114]: KB3054256
[115]: KB3054464
[116]: KB3055323
[117]: KB3055343
[118]: KB3055642
[119]: KB3056347
[120]: KB3059316
[121]: KB3059317
[122]: KB3060793
[123]: KB3061493
[124]: KB3061512
[125]: KB3062760
[126]: KB3063843
[127]: KB3064059
[128]: KB3068708
[129]: KB3071756
[130]: KB3072019
[131]: KB3072307
[132]: KB3074228
[133]: KB3074545
[134]: KB3074548
[135]: KB3075220
[136]: KB3075853
[137]: KB3076949
[138]: KB3077715
[139]: KB3078071
[140]: KB3078405
[141]: KB3078676
[142]: KB3079318
[143]: KB3080042
[144]: KB3080149
[145]: KB3080800
[146]: KB3082089
[147]: KB3083992
[148]: KB3084135
[149]: KB3084905
[150]: KB3086255
[151]: KB3087041
[152]: KB3087137
[153]: KB3087916
[154]: KB3091297
[155]: KB3092601
[156]: KB3092627
[157]: KB3095108
[158]: KB3095701
[159]: KB3096433
[160]: KB3097992
[161]: KB3097997
[162]: KB3098779
[163]: KB3099834
[164]: KB3100473
[165]: KB3100919
[166]: KB3100956
[167]: KB3102429
[168]: KB3103616
[169]: KB3103696
[170]: KB3103699
[171]: KB3103709
[172]: KB3104002
[173]: KB3109094
[174]: KB3109103
[175]: KB3109560
[176]: KB3109976
[177]: KB3110329
[178]: KB3112148
[179]: KB3112336
[180]: KB3115224
[181]: KB3118401
[182]: KB3119147
[183]: KB3121255
[184]: KB3121261
[185]: KB3121918
[186]: KB3122651
[187]: KB3122654
[188]: KB3123242
[189]: KB3123479
[190]: KB3123862
[191]: KB3124275
[192]: KB3124280
[193]: KB3125424
[194]: KB3126030
[195]: KB3126033
[196]: KB3126434
[197]: KB3126587
[198]: KB3126593
[199]: KB3127222
[200]: KB3127226
[201]: KB3128650
[202]: KB3132372
[203]: KB3133431
[204]: KB3133681
[205]: KB3133690
[206]: KB3133924
[207]: KB3134814
[208]: KB3134815
[209]: KB3135449
[210]: KB3135782
[211]: KB3135985
[212]: KB3135994
[213]: KB3136019
[214]: KB3137061
[215]: KB3137725
[216]: KB3137728
[217]: KB3138378
[218]: KB3138602
[219]: KB3138615
[220]: KB3138910
[221]: KB3138962
[222]: KB3139398
[223]: KB3139914
[224]: KB3139929
[225]: KB3140185
[226]: KB3140219
[227]: KB3140222
[228]: KB3140234
[229]: KB3140786
[230]: KB3141092
[231]: KB3142026
[232]: KB3142030
[233]: KB3142045
[234]: KB3144756
[235]: KB3145384
[236]: KB3146604
[237]: KB3146723
[238]: KB3146751
[239]: KB3146963
[240]: KB3147071
[241]: KB3148198
[242]: KB3148851
[243]: KB3149090
Network Card(s): 2 NIC(s) Installed.
[01]: Realtek PCIe FE Family Controller
Connection Name: Ethernet
Status: Hardware not present
[02]: Ralink RT3290 802.11bgn Wi-Fi Adapter
Connection Name: Wi-Fi_JChrist
DHCP Enabled: Yes
DHCP Server: 192.168.1.254
IP address(es)
[01]: 192.168.1.67
[02]: fe80::b92f:5843:74bf:752f
Hyper-V Requirements: VM Monitor Mode Extensions: Yes
Virtualization Enabled In Firmware: No
Second Level Address Translation: Yes
Data Execution Prevention Available: Yes
The following files are being opened:
Dump of system environment variables:
PROCESSOR_ARCHITEW6432=AMD64
COMPUTERNAME=KARLDHALIWAL
Platform=MCD
CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
BTK_PVTHEAP:6620=63c0000
HOMEPATH=\Users\Karljeet
PROCESSOR_REVISION=0001
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
TMP=C:\Users\Karljeet\AppData\Local\Temp
TEMP=C:\Users\Karljeet\AppData\Local\Temp
LOCALAPPDATA=C:\Users\Karljeet\AppData\Local
PUBLIC=C:\Users\Public
ILBDIR=C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\
CM2014DIR=C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\
USERDOMAIN=KARLDHALIWAL
Path=C:\ProgramData\Oracle\Java\javapath;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Hewlett-Packard\SimplePass\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files (x86)\Lighting Analysts\Shared\EosDWG_2013;C:\Program Files (x86)\Lighting Analysts\Shared;C:\Program Files (x86)\Lighting Analysts\Shared\CPM;C:\Program Files (x86)\Windows Live\Shared;c:\Program Files (x86)\Microsoft SQL Server\110\Tools\Binn\;c:\Program Files\Microsoft SQL Server\110\Tools\Binn\;c:\Program Files\Microsoft SQL Server\110\DTS\Binn\
PROCESSOR_LEVEL=22
PROCESSOR_IDENTIFIER=AMD64 Family 22 Model 0 Stepping 1, AuthenticAMD
PSModulePath=C:\Windows\system32\WindowsPowerShell\v1.0\Modules\;c:\Program Files (x86)\Microsoft SQL Server\110\Tools\PowerShell\Modules\
NUMBER_OF_PROCESSORS=4
CommonProgramFiles=C:\Program Files (x86)\Common Files
PCBRAND=Pavilion
asl.log=Destination=file
ProgramData=C:\ProgramData
ProgramW6432=C:\Program Files
FP_NO_HOST_CHECK=NO
OnlineServices=Online Services
SystemRoot=C:\Windows
BTK_WIN_TRACEBACK:6620=65a0aff0
BTK_ROOT_CTX:6620=643f5d0
SESSIONNAME=Console
CommonProgramW6432=C:\Program Files\Common Files
LOGONSERVER=\\MicrosoftAccount
USERPROFILE=C:\Users\Karljeet
USERDOMAIN_ROAMINGPROFILE=KARLDHALIWAL
APPDATA=C:\Users\Karljeet\AppData\Roaming
HOMEDRIVE=C:
USERNAME=Karljeet
PROCESSOR_ARCHITECTURE=x86
OS=Windows_NT
ComSpec=C:\Windows\system32\cmd.exe
SystemDrive=C:
windir=C:\Windows
ALLUSERSPROFILE=C:\ProgramData
The following Modules were loaded by Mathcad Prime:Module Name: MathcadPrime.exe
File: C:\Program Files (x86)\Mathcad\Mathcad Prime 2.0\MathcadPrime.exe; InternalName: MathcadPrime.exe; OriginalFilename: MathcadPrime.exe; FileVersion: 2.0.4430.15358; FileDescription: Mathcad Prime; Product: Mathcad Prime; ProductVersion: 2.0.4430.15358; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: Language Neutral;
Module Memory Size: 262144
Module Name: ntdll.dll
File: C:\Windows\SYSTEM32\ntdll.dll; InternalName: ntdll.dll; OriginalFilename: ntdll.dll.mui; FileVersion: 6.3.9600.18217 (winblue_ltsb.160124-0053); FileDescription: NT Layer DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.18217; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 1503232
Module Name: MSCOREE.DLL
File: C:\Windows\SYSTEM32\MSCOREE.DLL; InternalName: mscoree.dll; OriginalFilename: mscoree.dll; FileVersion: 6.3.9600.16384 (winblue_rtm.130821-1623); FileDescription: Microsoft .NET Runtime Execution Engine; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 352256
Module Name: KERNEL32.dll
File: C:\Windows\SYSTEM32\KERNEL32.dll; InternalName: kernel32; OriginalFilename: kernel32; FileVersion: 6.3.9600.18217 (winblue_ltsb.160124-0053); FileDescription: Windows NT BASE API Client DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.18217; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 1310720
Module Name: KERNELBASE.dll
File: C:\Windows\SYSTEM32\KERNELBASE.dll; InternalName: Kernelbase.dll; OriginalFilename: Kernelbase.dll.mui; FileVersion: 6.3.9600.18217 (winblue_ltsb.160124-0053); FileDescription: Windows NT BASE API Client DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.18217; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 880640
Module Name: TmUmEvt.dll
File: C:\Windows\SYSTEM32\tmumh\20019\AddOn\6.70.0.1078\TmUmEvt.dll; InternalName: TmUmEvt.dll; OriginalFilename: TmUmEvt.dll; FileVersion: 6.70.0.1078; FileDescription: Trend Micro User-Mode Hook Event Module; Product: Trend Micro Eyes; ProductVersion: 6.70; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: True; Language: English (United States);
Module Memory Size: 266240
Module Name: PSAPI.DLL
File: C:\Windows\SYSTEM32\PSAPI.DLL; InternalName: PSAPI; OriginalFilename: PSAPI; FileVersion: 6.3.9600.17415 (winblue_r4.141028-1500); FileDescription: Process Status Helper; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.17415; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 24576
Module Name: SHLWAPI.dll
File: C:\Windows\SYSTEM32\SHLWAPI.dll; InternalName: SHLWAPI; OriginalFilename: SHLWAPI.DLL.MUI; FileVersion: 6.3.9600.16384 (winblue_rtm.130821-1623); FileDescription: Shell Light-weight Utility Library; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 282624
Module Name: ADVAPI32.dll
File: C:\Windows\SYSTEM32\ADVAPI32.dll; InternalName: advapi32.dll; OriginalFilename: advapi32.dll.mui; FileVersion: 6.3.9600.16384 (winblue_rtm.130821-1623); FileDescription: Advanced Windows 32 Base API; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 507904
Module Name: MSVCR110.dll
File: C:\Windows\SYSTEM32\MSVCR110.dll; InternalName: msvcr110.dll; OriginalFilename: msvcr110.dll; FileVersion: 11.00.51106.1 built by: Q11REL; FileDescription: Microsoft® C Runtime Library; Product: Microsoft® Visual Studio® 2012; ProductVersion: 11.00.51106.1; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 876544
Module Name: MSVCP110.dll
File: C:\Windows\SYSTEM32\MSVCP110.dll; InternalName: msvcp110.dll; OriginalFilename: msvcp110.dll; FileVersion: 11.00.51106.1 built by: Q11REL; FileDescription: Microsoft® C Runtime Library; Product: Microsoft® Visual Studio® 2012; ProductVersion: 11.00.51106.1; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 544768
Module Name: msvcrt.dll
File: C:\Windows\SYSTEM32\msvcrt.dll; InternalName: msvcrt.dll; OriginalFilename: msvcrt.dll; FileVersion: 7.0.9600.17415 (winblue_r4.141028-1500); FileDescription: Windows NT CRT DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 7.0.9600.17415; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 798720
Module Name: combase.dll
File: C:\Windows\SYSTEM32\combase.dll; InternalName: COMBASE.DLL; OriginalFilename: COMBASE.DLL.MUI; FileVersion: 6.3.9600.16384 (winblue_rtm.130821-1623); FileDescription: Microsoft COM for Windows; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 1560576
Module Name: USER32.dll
File: C:\Windows\SYSTEM32\USER32.dll; InternalName: user32; OriginalFilename: user32; FileVersion: 6.3.9600.16384 (winblue_rtm.130821-1623); FileDescription: Multi-User Windows USER API Client DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 1388544
Module Name: GDI32.dll
File: C:\Windows\SYSTEM32\GDI32.dll; InternalName: gdi32; OriginalFilename: gdi32; FileVersion: 6.3.9600.18344 (winblue_ltsb.160518-1031); FileDescription: GDI Client DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.18344; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 1110016
Module Name: sechost.dll
File: C:\Windows\SYSTEM32\sechost.dll; InternalName: sechost.dll; OriginalFilename: sechost.dll.mui; FileVersion: 6.3.9600.16384 (winblue_rtm.130821-1623); FileDescription: Host for SCM/SDDL/LSA Lookup APIs; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Name: RPCRT4.dll
File: C:\Windows\SYSTEM32\RPCRT4.dll; InternalName: rpcrt4.dll; OriginalFilename: rpcrt4.dll.mui; FileVersion: 6.3.9600.16384 (winblue_rtm.130821-1623); FileDescription: Remote Procedure Call Runtime; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 761856
Module Name: SspiCli.dll
File: C:\Windows\SYSTEM32\SspiCli.dll; InternalName: security.dll; OriginalFilename: security.dll; FileVersion: 6.3.9600.18454 (winblue_ltsb.160820-0600); FileDescription: Security Support Provider Interface; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.18454; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 122880
Module Name: CRYPTBASE.dll
File: C:\Windows\SYSTEM32\CRYPTBASE.dll; InternalName: cryptbase.dll; OriginalFilename: cryptbase.dll; FileVersion: 6.3.9600.17415 (winblue_r4.141028-1500); FileDescription: Base cryptographic API DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.17415; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 40960
Module Name: bcryptPrimitives.dll
File: C:\Windows\SYSTEM32\bcryptPrimitives.dll; InternalName: bcryptprimitives.dll; OriginalFilename: bcryptprimitives.dll; FileVersion: 6.3.9600.18344 (winblue_ltsb.160518-1031); FileDescription: Windows Cryptographic Primitives Library; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.18344; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 344064
Module Name: IMM32.DLL
File: C:\Windows\system32\IMM32.DLL; InternalName: imm32; OriginalFilename: imm32; FileVersion: 6.3.9600.17415 (winblue_r4.141028-1500); FileDescription: Multi-User Windows IMM32 API Client DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.17415; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 159744
Module Name: MSCTF.dll
File: C:\Windows\SYSTEM32\MSCTF.dll; InternalName: MSCTF; OriginalFilename: MSCTF.DLL.MUI; FileVersion: 6.3.9600.16384 (winblue_rtm.130821-1623); FileDescription: MSCTF Server DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 1122304
Module Name: tmmon.dll
File: C:\Windows\SYSTEM32\tmumh\20019\TmMon\1.6.0.1172\tmmon.dll; InternalName: ; OriginalFilename: ; FileVersion: 1.6.0.1172; FileDescription: Trend Micro UMH Monitor Engine; Product: Trend Micro UMH; ProductVersion: 1.6; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 1167360
Module Name: sfc.dll
File: C:\Windows\SYSTEM32\sfc.dll; InternalName: sfc.dll; OriginalFilename: sfc.dll; FileVersion: 6.3.9600.16384 (winblue_rtm.130821-1623); FileDescription: Windows File Protection; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Name: VERSION.dll
File: C:\Windows\SYSTEM32\VERSION.dll; InternalName: version; OriginalFilename: VERSION.DLL; FileVersion: 6.3.9600.17415 (winblue_r4.141028-1500); FileDescription: Version Checking and File Installation Libraries; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.17415; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 32768
Module Name: sfc_os.DLL
File: C:\Windows\SYSTEM32\sfc_os.DLL; InternalName: sfc_os.dll; OriginalFilename: sfc_os.dll; FileVersion: 6.3.9600.17415 (winblue_r4.141028-1500); FileDescription: Windows File Protection; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.17415; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 61440
Module Name: mscoreei.dll
File: C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscoreei.dll; InternalName: mscoreei.dll; OriginalFilename: mscoreei.dll; FileVersion: 4.0.30319.34209 built by: FX452RTMGDR; FileDescription: Microsoft .NET Runtime Execution Engine; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.34209; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 516096
Module Name: clr.dll
File: C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dll; InternalName: clr.dll; OriginalFilename: clr.dll; FileVersion: 4.0.30319.34209 built by: FX452RTMGDR; FileDescription: Microsoft .NET Runtime Common Language Runtime - WorkStation; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.34209; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 6934528
Module Name: MSVCR120_CLR0400.dll
File: C:\Windows\SYSTEM32\MSVCR120_CLR0400.dll; InternalName: msvcr120_clr0400.dll; OriginalFilename: msvcr120_clr0400.dll; FileVersion: 12.00.52361.36361 built by: FX452RTMLDR; FileDescription: Microsoft® C Runtime Library; Product: Microsoft® Visual Studio® 12 CTP; ProductVersion: 12.00.52361.36361; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Name: mscorlib.ni.dll
File: C:\Windows\assembly\NativeImages_v4.0.30319_32\mscorlib\d03a3ddcd6a395878751c5e90fa16915\mscorlib.ni.dll; InternalName: mscorlib.dll; OriginalFilename: mscorlib.dll; FileVersion: 4.0.30319.34209 built by: FX452RTMGDR; FileDescription: Microsoft Common Language Runtime Class Library; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.34209; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 17215488
Module Name: ole32.dll
File: C:\Windows\SYSTEM32\ole32.dll; InternalName: OLE32.DLL; OriginalFilename: OLE32.DLL.MUI; FileVersion: 6.3.9600.16384 (winblue_rtm.130821-1623); FileDescription: Microsoft OLE for Windows; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 1216512
Module Name: kernel.appcore.dll
File: C:\Windows\SYSTEM32\kernel.appcore.dll; InternalName: kernel.appcore.dll; OriginalFilename: kernel.appcore.dll; FileVersion: 6.3.9600.17415 (winblue_r4.141028-1500); FileDescription: AppModel API Host; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.17415; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 36864
Module Name: uxtheme.dll
File: C:\Windows\system32\uxtheme.dll; InternalName: UxTheme.dll; OriginalFilename: UxTheme.dll.mui; FileVersion: 6.3.9600.16384 (winblue_rtm.130821-1623); FileDescription: Microsoft UxTheme Library; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 970752
Module Name: System.ni.dll
File: C:\Windows\assembly\NativeImages_v4.0.30319_32\System\8e0ad4a4567edbf6d93b095b5d4c27d6\System.ni.dll; InternalName: System.dll; OriginalFilename: System.dll; FileVersion: 4.0.30319.36350 built by: FX452RTMLDR; FileDescription: .NET Framework; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.36350; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 10100736
Module Name: WindowsBase.ni.dll
File: C:\Windows\assembly\NativeImages_v4.0.30319_32\WindowsBase\1fbd0444bbbbb4fc405e4695d8416acb\WindowsBase.ni.dll; InternalName: WindowsBase.dll; OriginalFilename: WindowsBase.dll; FileVersion: 4.0.30319.34292 built by: FX452RTMGDR; FileDescription: WindowsBase.dll; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.34292; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 3919872
Module Name: CRYPTSP.dll
File: C:\Windows\SYSTEM32\CRYPTSP.dll; InternalName: cryptsp.dll; OriginalFilename: cryptsp.dll; FileVersion: 6.3.9600.17415 (winblue_r4.141028-1500); FileDescription: Cryptographic Service Provider API; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.17415; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 102400
Module Name: rsaenh.dll
File: C:\Windows\system32\rsaenh.dll; InternalName: rsaenh.dll; OriginalFilename: rsaenh.dll.mui; FileVersion: 6.3.9600.16384 (winblue_rtm.130821-1623); FileDescription: Microsoft Enhanced Cryptographic Provider; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 196608
Module Name: bcrypt.dll
File: C:\Windows\SYSTEM32\bcrypt.dll; InternalName: bcrypt.dll; OriginalFilename: bcrypt.dll.mui; FileVersion: 6.3.9600.16384 (winblue_rtm.130821-1623); FileDescription: Windows Cryptographic Primitives Library; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Name: PresentationCore.ni.dll
File: C:\Windows\assembly\NativeImages_v4.0.30319_32\PresentationCore\ea3cd7063e71fd050fa6e6124f01da47\PresentationCore.ni.dll; InternalName: PresentationCore.dll; OriginalFilename: PresentationCore.dll; FileVersion: 4.0.30319.34292 built by: FX452RTMGDR; FileDescription: PresentationCore.dll; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.34292; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 11022336
Module Name: PresentationFramework.ni.dll
File: C:\Windows\assembly\NativeImages_v4.0.30319_32\Presentatio5ae0f00f#\2468f7d0d867c165d39f0f071a37974b\PresentationFramework.ni.dll; InternalName: PresentationFramework.dll; OriginalFilename: PresentationFramework.dll; FileVersion: 4.0.30319.34292; FileDescription: PresentationFramework.dll; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.34292; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: Language Neutral;
Module Memory Size: 18759680
Module Name: System.Xaml.ni.dll
File: C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Xaml\68c6ed1e2164f2a475a8b14afbe335d4\System.Xaml.ni.dll; InternalName: System.Xaml.dll; OriginalFilename: System.Xaml.dll; FileVersion: 4.0.30319.34292 built by: FX452RTMGDR; FileDescription: System.Xaml.dll; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.34292; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 1884160
Module Name: dwrite.dll
File: C:\Windows\SYSTEM32\dwrite.dll; InternalName: DWrite; OriginalFilename: DWrite; FileVersion: 6.3.9600.16384 (winblue_rtm.130821-1623); FileDescription: Microsoft DirectX Typography Services; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 1576960
Module Name: wpfgfx_v0400.dll
File: C:\Windows\Microsoft.NET\Framework\v4.0.30319\WPF\wpfgfx_v0400.dll; InternalName: wpfgfx_v0400.dll; OriginalFilename: wpfgfx_v0400.dll; FileVersion: 4.0.30319.34209 built by: FX452RTMGDR; FileDescription: wpfgfx_v0400.dll; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.34209; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 1671168
Module Name: OLEAUT32.dll
File: C:\Windows\SYSTEM32\OLEAUT32.dll; InternalName: OLEAUT32.DLL; OriginalFilename: ; FileVersion: 6.3.9600.18434; FileDescription: ; Product: ; ProductVersion: 6.3.9600.18434; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 618496
Module Name: PresentationNative_v0400.dll
File: C:\Windows\Microsoft.NET\Framework\v4.0.30319\WPF\PresentationNative_v0400.dll; InternalName: PresentationNative_v0400.dll; OriginalFilename: PresentationNative_v0400.dll; FileVersion: 4.0.30319.33440 built by: FX45W81RTMREL; FileDescription: PresentationNative_v0400.dll; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.33440; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 786432
Module Name: clrjit.dll
File: C:\Windows\Microsoft.NET\Framework\v4.0.30319\clrjit.dll; InternalName: clrjit.dll; OriginalFilename: clrjit.dll; FileVersion: 4.0.30319.34209 built by: FX452RTMGDR; FileDescription: Microsoft .NET Runtime Just-In-Time Compiler; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.34209; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 512000
Module Name: dwmapi.dll
File: C:\Windows\system32\dwmapi.dll; InternalName: dwmapi.dll; OriginalFilename: dwmapi.dll.mui; FileVersion: 6.3.9600.16384 (winblue_rtm.130821-1623); FileDescription: Microsoft Desktop Window Manager API; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 106496
Module Name: System.Core.ni.dll
File: C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Core\81ebb7ea56fe0d6fe781148dd818ff4c\System.Core.ni.dll; InternalName: System.Core.dll; OriginalFilename: System.Core.dll; FileVersion: 4.0.30319.34209 built by: FX452RTMGDR; FileDescription: .NET Framework; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.34209; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 6991872
Module Name: System.Drawing.ni.dll
File: C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Drawing\f2a9644247c1d0eddc967521093b3e87\System.Drawing.ni.dll; InternalName: System.Drawing.dll; OriginalFilename: System.Drawing.dll; FileVersion: 4.0.30319.36337 built by: FX452RTMLDR; FileDescription: .NET Framework; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.36337; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 1650688
Module Name: shell32.dll
File: C:\Windows\SYSTEM32\shell32.dll; InternalName: SHELL32; OriginalFilename: SHELL32.DLL.MUI; FileVersion: 6.3.9600.17031 (winblue_gdr.140221-1952); FileDescription: Windows Shell Common Dll; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.17031; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 19636224
Module Name: SHCORE.dll
File: C:\Windows\SYSTEM32\SHCORE.dll; InternalName: SHCORE; OriginalFilename: SHCORE.dll.mui; FileVersion: 6.3.9600.16384 (winblue_rtm.130821-1623); FileDescription: SHCORE; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 569344
Module Name: profapi.dll
File: C:\Windows\SYSTEM32\profapi.dll; InternalName: PROFAPI.DLL; OriginalFilename: PROFAPI.DLL; FileVersion: 6.3.9600.17415 (winblue_r4.141028-1500); FileDescription: User Profile Basic API; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.17415; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Name: WindowsCodecs.dll
File: C:\Windows\SYSTEM32\WindowsCodecs.dll; InternalName: WindowsCodecs; OriginalFilename: WindowsCodecs; FileVersion: 6.3.9600.18302 (winblue_ltsb.160409-0600); FileDescription: Microsoft Windows Codecs Library; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.18302; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 1486848
Module Name: ReachFramework.ni.dll
File: C:\Windows\assembly\NativeImages_v4.0.30319_32\ReachFramework\53f8d8ad5aff79e09a7ec4e3f4e49828\ReachFramework.ni.dll; InternalName: ReachFramework.dll; OriginalFilename: ReachFramework.dll; FileVersion: 4.0.30319.34292 built by: FX452RTMGDR; FileDescription: ReachFramework.dll; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.34292; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 2859008
Module Name: Ptc.License.Plpf.dll
File: C:\Program Files (x86)\Mathcad\Mathcad Prime 2.0\Ptc.License.Plpf.dll; InternalName: ; OriginalFilename: ; FileVersion: ; FileDescription: ; Product: ; ProductVersion: ; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: ;
Module Memory Size: 4829184
Module Name: NETAPI32.dll
File: C:\Windows\SYSTEM32\NETAPI32.dll; InternalName: NetApi32.DLL; OriginalFilename: NetApi32.DLL; FileVersion: 6.3.9600.17415 (winblue_r4.141028-1500); FileDescription: Net Win32 API DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.17415; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 77824
Module Name: WS2_32.dll
File: C:\Windows\SYSTEM32\WS2_32.dll; InternalName: ws2_32.dll; OriginalFilename: ws2_32.dll.mui; FileVersion: 6.3.9600.16384 (winblue_rtm.130821-1623); FileDescription: Windows Socket 2.0 32-Bit DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 323584
Module Name: COMCTL32.dll
File: C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_5.82.9600.17810_none_7c5b6194aa0716f1\COMCTL32.dll; InternalName: COMCTL32; OriginalFilename: COMCTL32.DLL.MUI; FileVersion: 5.82 (winblue_rtm.130821-1623); FileDescription: Common Controls Library; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 561152
Module Name: COMDLG32.dll
File: C:\Windows\SYSTEM32\COMDLG32.dll; InternalName: comdlg32; OriginalFilename: comdlg32.dll.mui; FileVersion: 6.3.9600.16384 (winblue_rtm.130821-1623); FileDescription: Common Dialogs DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 634880
Module Name: MSVCR100.dll
File: C:\Windows\SYSTEM32\MSVCR100.dll; InternalName: msvcr100_clr0400.dll; OriginalFilename: msvcr100_clr0400.dll; FileVersion: 10.00.40219.325; FileDescription: Microsoft® C Runtime Library; Product: Microsoft® Visual Studio® 2010; ProductVersion: 10.00.40219.325; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 782336
Module Name: MSVCP100.dll
File: C:\Windows\SYSTEM32\MSVCP100.dll; InternalName: msvcp100.dll; OriginalFilename: msvcp100.dll; FileVersion: 10.00.40219.325; FileDescription: Microsoft® C Runtime Library; Product: Microsoft® Visual Studio® 2010; ProductVersion: 10.00.40219.325; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 430080
Module Name: WINSPOOL.DRV
File: C:\Windows\SYSTEM32\WINSPOOL.DRV; InternalName: winspool.drv; OriginalFilename: winspool.drv.mui; FileVersion: 6.3.9600.16384 (winblue_rtm.130821-1623); FileDescription: Windows Spooler Driver; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 413696
Module Name: MPR.dll
File: C:\Windows\SYSTEM32\MPR.dll; InternalName: mpr.dll; OriginalFilename: mpr.dll.mui; FileVersion: 6.3.9600.16384 (winblue_rtm.130821-1623); FileDescription: Multiple Provider Router DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 90112
Module Name: netutils.dll
File: C:\Windows\SYSTEM32\netutils.dll; InternalName: NETUTILS.DLL; OriginalFilename: NETUTILS.DLL; FileVersion: 6.3.9600.17415 (winblue_r4.141028-1500); FileDescription: Net Win32 API Helpers DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.17415; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Name: srvcli.dll
File: C:\Windows\SYSTEM32\srvcli.dll; InternalName: SRVCLI.DLL; OriginalFilename: SRVCLI.DLL; FileVersion: 6.3.9600.17415 (winblue_r4.141028-1500); FileDescription: Server Service Client DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.17415; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 118784
Module Name: wkscli.dll
File: C:\Windows\SYSTEM32\wkscli.dll; InternalName: WKSCLI.DLL; OriginalFilename: WKSCLI.DLL; FileVersion: 6.3.9600.17415 (winblue_r4.141028-1500); FileDescription: Workstation Service Client DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.17415; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 69632
Module Name: NSI.dll
File: C:\Windows\SYSTEM32\NSI.dll; InternalName: nsi.dll; OriginalFilename: nsi.dll; FileVersion: 6.3.9600.17415 (winblue_r4.141028-1500); FileDescription: NSI User-mode interface DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.17415; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 28672
Module Name: System.Configuration.ni.dll
File: C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Configuration\63a5347b50dfb4d5be43725141f23119\System.Configuration.ni.dll; InternalName: System.Configuration.dll; OriginalFilename: System.Configuration.dll; FileVersion: 4.0.30319.34209 built by: FX452RTMGDR; FileDescription: System.Configuration.dll; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.34209; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 974848
Module Name: urlmon.dll
File: C:\Windows\SYSTEM32\urlmon.dll; InternalName: UrlMon.dll; OriginalFilename: UrlMon.dll.mui; FileVersion: 11.00.9600.18378 (winblue_ltsb.160611-0600); FileDescription: OLE32 Extensions for Win32; Product: Internet Explorer; ProductVersion: 11.00.9600.18378; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 1359872
Module Name: iertutil.dll
File: C:\Windows\SYSTEM32\iertutil.dll; InternalName: IeRtUtil.dll; OriginalFilename: IeRtUtil.dll.mui; FileVersion: 11.00.9600.16384 (winblue_rtm.130821-1623); FileDescription: Run time utility for Internet Explorer; Product: Internet Explorer; ProductVersion: 11.00.9600.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 2310144
Module Name: WININET.dll
File: C:\Windows\SYSTEM32\WININET.dll; InternalName: wininet.dll; OriginalFilename: wininet.dll.mui; FileVersion: 11.00.9600.16384 (winblue_rtm.130821-1623); FileDescription: Internet Extensions for Win32; Product: Internet Explorer; ProductVersion: 11.00.9600.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 2478080
Module Name: USERENV.dll
File: C:\Windows\SYSTEM32\USERENV.dll; InternalName: userenv; OriginalFilename: userenv.dll.mui; FileVersion: 6.3.9600.16384 (winblue_rtm.130821-1623); FileDescription: Userenv; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 110592
Module Name: Secur32.dll
File: C:\Windows\SYSTEM32\Secur32.dll; InternalName: secur32.dll; OriginalFilename: secur32.dll; FileVersion: 6.3.9600.17415 (winblue_r4.141028-1500); FileDescription: Security Support Provider Interface; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.17415; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Name: System.Xml.ni.dll
File: C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Xml\c523432581e28983f20ffe899c1c537d\System.Xml.ni.dll; InternalName: System.Xml.dll; OriginalFilename: System.Xml.dll; FileVersion: 4.0.30319.34281 built by: FX452RTMGDR; FileDescription: .NET Framework; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.34281; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 7794688
Module Name: PresentationFramework.Luna.ni.dll
File: C:\Windows\assembly\NativeImages_v4.0.30319_32\Presentatio1c968d57#\c79b14e553337a666bce8d4fc19e3649\PresentationFramework.Luna.ni.dll; InternalName: PresentationFramework.Luna.dll; OriginalFilename: PresentationFramework.Luna.dll; FileVersion: 4.0.30319.33440 built by: FX45W81RTMREL; FileDescription: PresentationFramework.Luna.dll; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.33440; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 671744
Module Name: mscms.dll
File: C:\Windows\SYSTEM32\mscms.dll; InternalName: MSCMS.DLL; OriginalFilename: MSCMS.DLL.MUI; FileVersion: 6.3.9600.16384 (winblue_rtm.130821-1623); FileDescription: Microsoft Color Matching System DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 520192
Module Name: PresentationFramework.Aero.ni.dll
File: C:\Windows\assembly\NativeImages_v4.0.30319_32\Presentatio1c9175f8#\2c9d2f65ec27d234b2b91722ce6ae907\PresentationFramework.Aero.ni.dll; InternalName: PresentationFramework.Aero.dll; OriginalFilename: PresentationFramework.Aero.dll; FileVersion: 4.0.30319.33440 built by: FX45W81RTMREL; FileDescription: PresentationFramework.Aero.dll; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.33440; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 462848
Module Name: PresentationFramework.Aero2.ni.dll
File: C:\Windows\assembly\NativeImages_v4.0.30319_32\Presentatioaec034ca#\b36619506a7dd1242973b906f7590bbd\PresentationFramework.Aero2.ni.dll; InternalName: PresentationFramework.Aero2.dll; OriginalFilename: PresentationFramework.Aero2.dll; FileVersion: 4.0.30319.34209 built by: FX452RTMGDR; FileDescription: PresentationFramework.Aero2.dll; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.34209; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 471040
Module Name: WindowsFormsIntegration.ni.dll
File: C:\Windows\assembly\NativeImages_v4.0.30319_32\WindowsForm0b574481#\676315bb7a142485ca5f0ac6cc8bf08d\WindowsFormsIntegration.ni.dll; InternalName: WindowsFormsIntegration.dll; OriginalFilename: WindowsFormsIntegration.dll; FileVersion: 4.0.30319.34209 built by: FX452RTMGDR; FileDescription: Windows Presentation Foundation WindowsForms Integration Library; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.34209; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 258048
Module Name: d3d9.dll
File: C:\Windows\SYSTEM32\d3d9.dll; InternalName: D3D9.dll; OriginalFilename: D3D9.dll; FileVersion: 6.3.9600.17415 (winblue_r4.141028-1500); FileDescription: Direct3D 9 Runtime; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.17415; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 1912832
Module Name: aticfx32.dll
File: C:\Windows\SYSTEM32\aticfx32.dll; InternalName: aticfx32.dll; OriginalFilename: aticfx32.dll; FileVersion: 8.17.10.1247; FileDescription: aticfx32.dll; Product: AMD Inc. Radeon DirectX 11 Driver; ProductVersion: 8.17.10.1247; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: True; Language: English (United States);
Module Memory Size: 1114112
Module Name: atiu9pag.dll
File: C:\Windows\SYSTEM32\atiu9pag.dll; InternalName: atiu9pag.dll; OriginalFilename: atiu9pag.dll; FileVersion: 8.14.01.6354; FileDescription: atiu9pag.dll; Product: Advanced Micro Devices, Inc PowerXpress Vista User Mode Driver; ProductVersion: 8.14.01.6354; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: True; Language: English (United States);
Module Name: atiumdag.dll
File: C:\Windows\SYSTEM32\atiumdag.dll; InternalName: atiumdag.dll; OriginalFilename: atiumdag.dll; FileVersion: 9.14.10.01001; FileDescription: atiumdag.dll; Product: Advanced Micro Devices, Inc. Radeon DirectX Universal Driver; ProductVersion: 9.14.10.01001; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: True; Language: English (United States);
Module Memory Size: 6615040
Module Name: atiumdva.dll
File: C:\Windows\SYSTEM32\atiumdva.dll; InternalName: atiumdva.dll; OriginalFilename: atiumdva.dll; FileVersion: 8.14.10.0429; FileDescription: Radeon Video Acceleration Universal Driver; Product: Advanced Micro Devices, Inc. Radeon Video Acceleration Universal Driver; ProductVersion: 8.14.10.0429; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: True; Language: English (United States);
Module Memory Size: 8314880
Module Name: UIAutomationTypes.ni.dll
File: C:\Windows\assembly\NativeImages_v4.0.30319_32\UIAutomationTypes\c8849d6fd3bee972ec451baea15949ca\UIAutomationTypes.ni.dll; InternalName: UIAutomationTypes.dll; OriginalFilename: UIAutomationTypes.dll; FileVersion: 4.0.30319.33440 built by: FX45W81RTMREL; FileDescription: UIAutomationTypes.dll; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.33440; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Name: UIAutomationCore.dll
File: C:\Windows\SYSTEM32\UIAutomationCore.dll; InternalName: UIAutomationCore.dll; OriginalFilename: UIAutomationCore.dll.mui; FileVersion: 7.2.9600.16384 (winblue_rtm.130821-1623); FileDescription: Microsoft UI Automation Core; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 1036288
Module Name: clbcatq.dll
File: C:\Windows\SYSTEM32\clbcatq.dll; InternalName: CLBCATQ.DLL; OriginalFilename: CLBCATQ.DLL; FileVersion: 2001.12.10530.17415 (winblue_r4.141028-1500); FileDescription: COM+ Configuration Catalog; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.17415; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 577536
Module Name: sxs.dll
File: C:\Windows\SYSTEM32\sxs.dll; InternalName: SXS.DLL; OriginalFilename: SXS.DLL.MUI; FileVersion: 6.3.9600.16384 (winblue_rtm.130821-1623); FileDescription: Fusion 2.5; Product: Microsoft® Windows® Operating System; ProductVersion: 6.3.9600.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Name: System.Windows.Forms.ni.dll
File: C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Windows.Forms\98247d38980830c0d4aac7ae15c177af\System.Windows.Forms.ni.dll; InternalName: System.Windows.Forms.dll; OriginalFilename: System.Windows.Forms.dll; FileVersion: 4.0.30319.34250 built by: FX452RTMGDR; FileDescription: .NET Framework; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.34250; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 12910592
Module Name: diasymreader.dll
File: C:\Windows\Microsoft.NET\Framework\v4.0.30319\diasymreader.dll; InternalName: diasymreader.dll; OriginalFilename: diasymreader.dll; FileVersion: 12.0.20806.33440 built by: FX45W81RTMREL; FileDescription: Dia based SymReader; Product: Microsoft® .NET Framework; ProductVersion: 12.0.20806.33440; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 856064
Here is the content to the latest log file.
Architecture: x86
Exception data:
System.Object:
09:57:58 09/23/2016
Domain: WORKGROUP
[02]: KB2868626
[03]: KB2883200
[04]: KB2887595
[05]: KB2894852
[06]: KB2894856
[07]: KB2903939
[08]: KB2911106
[09]: KB2919355
[10]: KB2919394
[11]: KB2920189
[12]: KB2928680
[13]: KB2934520
[14]: KB2954879
[15]: KB2955164
[16]: KB2959626
[17]: KB2961908
[18]: KB2962409
[19]: KB2962806
[20]: KB2965142
[21]: KB2965500
[22]: KB2966826
[23]: KB2966828
[24]: KB2967917
[25]: KB2968296
[26]: KB2969339
[27]: KB2971203
[28]: KB2972103
[29]: KB2972213
[30]: KB2973114
[31]: KB2975061
[32]: KB2975719
[33]: KB2976627
[34]: KB2976978
[35]: KB2977629
[36]: KB2977765
[37]: KB2978122
[38]: KB2978126
[39]: KB2984006
[40]: KB2987107
[41]: KB2989647
[42]: KB2989930
[43]: KB2990967
[44]: KB2993100
[45]: KB2994290
[46]: KB2995004
[47]: KB2995388
[48]: KB2996799
[49]: KB2998174
[50]: KB2999226
[51]: KB3000850
[52]: KB3003057
[53]: KB3003667
[54]: KB3004361
[55]: KB3004365
[56]: KB3004545
[57]: KB3008923
[58]: KB3012199
[59]: KB3012235
[60]: KB3012702
[61]: KB3013172
[62]: KB3013531
[63]: KB3013538
[64]: KB3013769
[65]: KB3013791
[66]: KB3013816
[67]: KB3014442
[68]: KB3015696
[69]: KB3018133
[70]: KB3019978
[71]: KB3020338
[72]: KB3020370
[73]: KB3021910
[74]: KB3022777
[75]: KB3023219
[76]: KB3023222
[77]: KB3024751
[78]: KB3024755
[79]: KB3029432
[80]: KB3029603
[81]: KB3029606
[82]: KB3030377
[83]: KB3030947
[84]: KB3033446
[85]: KB3035126
[86]: KB3035583
[87]: KB3036612
[88]: KB3037576
[89]: KB3037579
[90]: KB3037924
[91]: KB3038002
[92]: KB3038936
[93]: KB3041857
[94]: KB3042085
[95]: KB3042553
[96]: KB3044374
[97]: KB3044673
[98]: KB3045634
[99]: KB3045685
[100]: KB3045717
[101]: KB3045719
[102]: KB3045755
[103]: KB3045992
[104]: KB3045999
[105]: KB3046017
[106]: KB3046480
[107]: KB3046737
[108]: KB3047254
[109]: KB3048043
[110]: KB3052480
[111]: KB3053863
[112]: KB3053946
[113]: KB3054169
[114]: KB3054256
[115]: KB3054464
[116]: KB3055323
[117]: KB3055343
[118]: KB3055642
[119]: KB3056347
[120]: KB3059316
[121]: KB3059317
[122]: KB3060793
[123]: KB3061493
[124]: KB3061512
[125]: KB3062760
[126]: KB3063843
[127]: KB3064059
[128]: KB3068708
[129]: KB3071756
[130]: KB3072019
[131]: KB3072307
[132]: KB3074228
[133]: KB3074545
[134]: KB3074548
[135]: KB3075220
[136]: KB3075853
[137]: KB3076949
[138]: KB3077715
[139]: KB3078071
[140]: KB3078405
[141]: KB3078676
[142]: KB3079318
[143]: KB3080042
[144]: KB3080149
[145]: KB3080800
[146]: KB3082089
[147]: KB3083992
[148]: KB3084135
[149]: KB3084905
[150]: KB3086255
[151]: KB3087041
[152]: KB3087137
[153]: KB3087916
[154]: KB3091297
[155]: KB3092601
[156]: KB3092627
[157]: KB3095108
[158]: KB3095701
[159]: KB3096433
[160]: KB3097992
[161]: KB3097997
[162]: KB3098779
[163]: KB3099834
[164]: KB3100473
[165]: KB3100919
[166]: KB3100956
[167]: KB3102429
[168]: KB3103616
[169]: KB3103696
[170]: KB3103699
[171]: KB3103709
[172]: KB3104002
[173]: KB3109094
[174]: KB3109103
[175]: KB3109560
[176]: KB3109976
[177]: KB3110329
[178]: KB3112148
[179]: KB3112336
[180]: KB3115224
[181]: KB3118401
[182]: KB3119147
[183]: KB3121255
[184]: KB3121261
[185]: KB3121918
[186]: KB3122651
[187]: KB3122654
[188]: KB3123242
[189]: KB3123479
[190]: KB3123862
[191]: KB3124275
[192]: KB3124280
[193]: KB3125424
[194]: KB3126030
[195]: KB3126033
[196]: KB3126434
[197]: KB3126587
[198]: KB3126593
[199]: KB3127222
[200]: KB3127226
[201]: KB3128650
[202]: KB3132372
[203]: KB3133431
[204]: KB3133681
[205]: KB3133690
[206]: KB3133924
[207]: KB3134814
[208]: KB3134815
[209]: KB3135449
[210]: KB3135782
[211]: KB3135985
[212]: KB3135994
[213]: KB3136019
[214]: KB3137061
[215]: KB3137725
[216]: KB3137728
[217]: KB3138378
[218]: KB3138602
[219]: KB3138615
[220]: KB3138910
[221]: KB3138962
[222]: KB3139398
[223]: KB3139914
[224]: KB3139929
[225]: KB3140185
[226]: KB3140219
[227]: KB3140222
[228]: KB3140234
[229]: KB3140786
[230]: KB3141092
[231]: KB3142026
[232]: KB3142030
[233]: KB3142045
[234]: KB3144756
[235]: KB3145384
[236]: KB3146604
[237]: KB3146723
[238]: KB3146751
[239]: KB3146963
[240]: KB3147071
[241]: KB3148198
[242]: KB3148851
[243]: KB3149090
DHCP Enabled: Yes
IP address(es)
[01]: 192.168.1.67
Platform=MCD
PROCESSOR_LEVEL=22
PCBRAND=Pavilion
FP_NO_HOST_CHECK=NO
SESSIONNAME=Console
HOMEDRIVE=C:
USERNAME=Karljeet
OS=Windows_NT
SystemDrive=C:
windir=C:\Windows
HI.
It could be that a shut down for turning off the computer, that file preserve some bad configuration.
Try the following:
Make a copy of the file (or maybe the entire folder where it is):
and then delete it. See if the program works.
Best regards.
Alvaro.
As Alvaro notes, it has a problem with this file: C:\Users\Karljeet\AppData\Local\PTC\MathcadPrime.exe_Url_ekf0ceoyb5f0c5jtvxm1owuocajql20q\2.0.4430.15358\user.config.
Please post a copy of the file. Attach it, rather than copying and pasting the contents into a post. It would have been better if you had attached the log files, because then we wouldn't have to scroll past a huge wall of text to get to the next post in the thread.
