Help file issue
SteveKeen
Help file issue
This relates to uninstalled Java software on my PC it seems, but it's still an annoying opening.
I tried to download the data_files.zip file and received the attached message: "javaw.exe--Unable to locate component... The application has failed to start because ISWUL.dll was not found. Re-installing the application may fix this problem."
0 REPLIES 0
