Hi all,
I'm new here, so excuse me if this question has already been answered ![]()
In MathCad 14:
When I go to:
Inset
Control
Web Control
And select Radio button, I am unable to set the font to Arial - the Default font seems to be Times New Roman?.
This is a bit annoying as this is not a problem when I use the "non" Web Control radio Button.
Please see attached PDF file for details
Can anyone help?
Jens
I'm sure this can be done. Try following the instructions below.
And choose your font in there.
Mike
After posting my first post I have just realised that you said.....
And select Radio button, I am unable to set the font to Arial - the Default font seems to be Times New Roman?. This is a bit annoying as this is not a problem when I use the "non" Web Control radio Button.
Your right it doesn't look like you can change the font. Why don't you use another object if the font really bothers you.
Mike
I use pictures as name of web radiobuttons and have no problem with font, Greek letters, sub- and superscripts etc.
Try please my Mathcad Server:
http://twt.mpei.ac.ru/MCS/Worksheets/HEDH/FC-40.xmcd
or see the picture:
Good example Valery, totally slipped my mine.
Mike
Mike
Thanks, Mike!
It will be better to use the (up-down) list - we can use links in names of items!
One example:
http://twt.mpei.ac.ru/MCS/Worksheets/Thermal/SatLine-R-134a.xmcd
Thanks for you help so far, it seems to come down to doing a work around.
I'll se what I can come up with ![]()
Warm regards
Jens
As Valerys example shows, a list box IMO would be the best way to go.
Mike
We need Combo box in Mathcad:
