I am struggling with how the Combobox works and its capabilities.
I created two combo boxes, and I could populate some variables using the first combo box, but I also need to be able to change the results based on a selection from the second combo box
How can I do that?
Attached is the Mathcad sheet in prime 7
How about the file attached.
