Help with a double "IF" statement
  • October 6, 2016
  • 5 replies
  • 5153 views
Hello.
I'm having trouble combining 2 "IF" statements. I'm sure this is a piece of cake for you experts.
Here is the general form of my program (the actual equations are more complicated).
X=A   If  M=1
X=B   If M=2  and If N=1
X=C  If M=2 and If N=0  (or simply X=C  otherwise)
Thanks, Al Clark
You're posting this in the general community help section - meaning help with the community site itself, not some specific PTC software.  If you can tell us what software you're using, we can provide a better response.
in case that you need to define model relations, please see following code.
/* M, N are integer values
X=C
if M==1
  X=A
endif
if M==2
  if N==1
    X=B
  endif
endif
MH
Since you have posted in the Mathcad forums before I assume this is a Mathcad question, in which case the best solution is a small program:
Note that you cannot just type "return", "if" and "otherwise". They must be entered from the programming toolbar.
Toby Metcalf‌ please move this to the Mathcad forums.
Thanks Richard
Hi
Even so, it would be fine, do not you think?
aclark-31-VisitorAuthor
Thanks everyone for your help. I didn't realize that I would initiate such a discussion.
Actually all I needed was to be steered to the Boolean "and", and then I was all set.
Regards, Al
