Help with a program function.
lvl107
20-Turquoise
  Hello, Everyone.
  Need help creating a program function as the above.
      Thanks in advance for your time and help.
            Regards.
LucMeekes
(To:lvl107)
Or similar...
I'm leaving out the operators (all "+") and the results (also all the same), and just give the bare numbers:
What you can see from the structure is that this algorithm is screaming for a recursive approach. But I'm not not clear enough now to think about that....
Other output, shows you what the very first column is for:
LucMeekes
(To:lvl107)
Or similar...
lvl107
20-Turquoise
(To:LucMeekes)
  Thanks and thanks for your time and help, again, Luc.
   Best Regards.
       Loi
