Help with obj.SaveAs API script
ptc-5341196
I've developed an application using an embedded MathCAD worksheet in Excel. The macro passes an array of input data into MathCAD and retrieves an array of calculation results. I would like to be able to save the embedded MathCAD file as a stand alone .xmcd file using a macro. I'm very confused about the format of the SaveAs function since the Developer's guide doesn't provide an example that uses it. Can anyone please provide some format/info/example on its use? Thank you very much.
My code is:
Sub Save_MathCAD_Object()
' Define variables and types
Dim MathcadObject As OLEObject
Dim file_loc As String
' Unprotect worksheet
Sheets("Embedded_MathCAD_file").Unprotect Password:="SDC_224"
file_loc = Sheets("Embedded_MathCAD_file").Cells(2, 1)
' Set a reference to the Mathcad object on the sheet
Set MathcadObject = Sheets("Embedded_MathCAD_file").OLEObjects(1)
' Save MathCAD file
MathcadObject.SaveAs "C:\Users\sdcollins\Desktop\MathCADFiles\Test.xcmd", 0
' Protect worksheet
Sheets("Embedded_MathCAD_file").Protect Password:="SDC_224"
End Sub
0 REPLIES 0
