I've run into a little bit of a problem. I've got a solve block that is constrained by four equations, but I've only got two variables. The solution it gives me meets the criteria for two of the equations, but for the other two it doesn't. Any help on this would be great. Thanks.
You only have one equality, with three inequalities. This means that you are likely to have either an infinite number of possible solutions or none! Looks like the latter to me.
Alan
