Hexagonal packing
Jbryant61
Hexagonal packing
Would anyone be able to start me off with creating a graphic showing 6 hexagonally packed objects (described by gaussians).
I would like to be able to change the FWHM of the gaussian, and the separtion of the objects and then determine the overlap of the objects.
Jason
8 REPLIES 8
By hexagonal packing, you mean :
a Mathcad chain saw of 5 crosswise cuts for 6 logs.
Salut Jason, Jean
Jbryant61
(To:ptc-1368288)
Hi Jean, good to hear from you!
this is what I mean't.
Regards
Jason
>you!
>this is what I meant.
>Regards
>Jason
________________________
attempted something that plots 3D,
but the image makes no sense !
>you!
>Regards
>Jason
Jason,
Look at that simple extractor, and the beautiful image. For a serial extract of different level ranges, a piece of programme must be designed. Then extract the size that contains the valued pixels, then place the 6 images in an hexagonal disposition.
Jean
... added RGB cross hair at specified X,Y coordinate.
From recollection, you were looking for that gadget.
Jean
Jbryant61
(To:ptc-1368288)
Many thanks Jean.
Jason
RichardJ
(To:Jbryant61)
Do you mean this?
Richard
Jbryant61
(To:RichardJ)
Perfect! - thankyou.
Jason
