Im still working on a routine and im stucking in defining a routine for each row of the vector.
I need to define a certain condition and apply it to every row of the vectors
The rows are depending on the Loadcases, which are read in mathcad.
I still dont really understand 😞
Thx 😃
In this case i need to write the maximum value of the calculated 5 pressures to excel for every loadcase.
You didn't attach tha datafile so we just see errors in your sheet.
Could it be that you are looking for something like this:
yes best thx mm having little problems with the notation so far.
I hope i can make a workaround and get rid with the "NaN" values.
? To what extent does this have to do with your original question here?
hmm i was only meaning sometimes i dont know how to write the condition and that stuff because i dont know the exact programmcode.
I could manage to read out the maximal pressure with your help but today i was occuring the Problem that a variable for calculating the pressure is NaN.
I was trying to write a if condition with IsNaN to set the variable from NaN to a certain value, so that i can calculate the pressure and i dont get an error.
Or to exclude for example pT3 if there is a NaN failure.
I also tryed the function "on error". MMM
I was thinking the if condition to set a variable to a defined value if NaN occurs would work faster.
NaN's are treated as 0's by the "max" function. So they will only be a problem if the rest of the five values all are negative.
I could happyly manage it. I want to share it with you how i solved it:
As you can see i have 5 pressures now i wrote for the pressure formula:
pt1=0 on error 5*b/x (with all pTs)
with p=5*b/x
so i can manage the problem, when i have only pT1 and all others are without value.
I can then make the max(pT1,pT2,pT3,pT4,pT5) without an error when only 1 or 2 pT is available to calculate the max
