We have a network installation of MathCAD 14 that is installed on my computer. I am trying to locate the server name that the license manager is located on. Is there a way to look for that within MathCAD?
I asked Google ... server location for a MathCAD 14
and get link to http://lindhardt.net/mc14/Install_Guide.pdf
Inside the document there is following information:
To access the Mathcad License Setup wizard at any time, type mathcad /license at a command prompt. This allows you to change the license server or file used by the workstation.
Thank you Martin, that did it!
