How can I input long expressions which need to go into multiple lines?
dchandiramani
How can I input longer than single line expressions?
5 REPLIES 5
You can break an expression into mulitple lines at any addition. Use [Ctl-Enter] to add a:
RichardJ
(To:LucMeekes)
Unless you are using Mathcad Prime
Thank you Richard. I need to do it in Mathcad Prime.
Sorry, but this feature is not currently available in Prime.
In that case you are left with (at least) the following option:
e1:=....
e2:=....
e3:=....
e:=e1+e2+e3
And if you really want the expressions to be a single item, you can do essentially the same in a program.
e:=|e1<-....
     |e2<-....
     |e3<-....
     |e1+e2+e3
