How can i evaluate the moment using an array for variable, then finf max and min of interior values
SFares
How can i evaluate the moment function using an array for my variables. Also need to determine the max moment and minimum moment values at interior points excluding the first value at x=0, and the max x value? please attached sheet where i have my questions inside the sheet. Thanks!
(To:SFares)
The attached sheet should help.
(To:SFares)
SFares
(To:Werner_E)
Thanks alot Werner!
