3-Newcomer
May 9, 2010
How do I enter a table w 2000+ entries?
  • May 9, 2010
  • 2221 views
I have a complex data file that contains, among many other items, 2047 line entries, where each of these lines contains 1 integer number. I wanted to create a table of these numbers as I would in Mxx. How do I do that? In trying to paste the numbers as I would in M14, I found that the Edit ribbon box does not allow me to paste when the table|matrix cell contains data, and that data is highlighted. I must delete the cell data first. This is similar to a bug that I reported.
So...I guess that I could create an Excel file, and import or copy/paste from there --- which I attempted, only to [apparently] find that M' doesn't import xls files? At any rate, an awkward step just to get some data into M'. What am I missing?
Rich
http://www.downeastengineering.com/
On the "Functions" tab there is a "File Access" drop down menu that contains all sorts of import options.
This is probably a clunky way of dealing with your data but it does provide more options.
Philip
___________________
Nobody can hear you scream in Euclidean space.
Ninetrees3-NewcomerAuthor
3-Newcomer
May 10, 2010
I'll follow up on these more, but at first blush they don't seem to do what I need. The file has different kinds of data in it. In M14, I just copy the lines of integers [in plain text format], r-click the table in M14, and select Paste Table. That gets me the data embedded in the doc, which is what I want, because I don't want to have to track the external file (even though it is archived for reference purposes in the future).
Rich
MP1 only imports .XLSX files, which are the Office 2007 variety.
TTFN,
Eden
