How do I open a mathcad prime (.mcdx) file in mathcad 14 or15?
ptc-4237493
Do I need to convert this file first? The convertor converts .mcd files to .mcdx format but I haven't been able to convert files the other way. I would like to be able to open .mcdx files using mathcad 14 or 15, or convert a .mcdx file to .mcd format. Please can you help?
Delali Dei
Hello!
Mathcad Prime can only save files in following formats: ".mcdx", ".pdf" (using PDF printer), ".xps". Convert the file in format ".mcdx" into ".mcd" or ".xmcd" is impossible.
Is not possible you mean
Mike
Yes .
