How do i know which coefficients go with which independent variables in a second order polynomial with 3 independent variables? I have extracted 10 coefficients but now want the equations to use elsewhere.
Which version of Mathcad, and how did you generate the polynomial coefficients?
I have Mathcad 15. I created a matrix M with the 3 independent variables (W,X,Y) then used regress with the dependent variable Z and order 2 (Eq2 = regress(M,Z,2) ) . When I display Eq2 = ... I get the vector with the coefficients list after the 3,3,2 but when I use these the results are not close but with regress with order 1 and the same data the results are somewhat close.
