Hi guys, pretty basic question im aware but still i seem to be unable to find an anwser:
I have a Variable: "Tee_type", which can be either equal to a "u", "t" or "w"......
what i need to be able to do is:
h(Tee_type):= if(Tee_type="u", something, something else)....
but i dont seem to be able to type it out properly, can anyone give me step-by-step instructions on how to type this function out. any help would be much appreciated.
Thanks!
We can use the if-function:
A:=if(a>b,... ,if(a<f,...,if(d>t,...,f( ...)))))
or
the if-operator
See the fig. 6 here http://twt.mpei.ac.ru/ochkov/Mathcad_14/MathcadWorkSheetAsFlowChartEng.pdf
Ah, found the issue!
i wasn't using the bolean operators - knew it had to be a simple fix!
cheers, Ricky
cheers, Ricky
Richardo,
It is always good practice to provide an example of the solved issue (even in this simple case) for other users to follow the thread.
Cheers
Mike
