How to Create A Loop to Calculate a Cummulative Variable
ptc-5031264
I am new to Mathcad and I am having a problem with programming a simple loop. In the attached mathcad sheet I want to calculate the value of (q) and then I want it to add to (s) and then re-calculate (q) for the new (s) value. However, I am unable to do this using the programming function as shown in the Mathcad sheet. It seems to give the same answer through the loop. Please help. Thank you.
5 REPLIES 5
just need to move the summing line inside the for loop.
Regards
Andy
(To:ptc-5031264)
The attached examples of two different ways should help
Many thanks for the answer. It was very helpful. I got another question on how I could return the values of both s and q in the mathcad sheet. Thank you.
(To:ptc-5031264)
Are you interested only in the last value of the iterations of both of them or do you need the whole "history"?
Said another way - do you want vectors for s and q or rather a single value (from the last iteration)?
(To:ptc-5031264)
I think one of the two attached methods should do the job
