Hi to all
I try to see bode and phase plot of flyback converter in DCM mode on MATHCAD 15
After write equations i can see all result is ok.
My problem is, i don't know how can i understand crossover frequency on 0db? I don't know which equation i can use to give this frequency?
Make AR a function of omega, and then solve for omega when AR=0.
Note that Mathcad has sqrt(-1) built in. You get it by typing 1i or 1j.
Thanks a lot Mr. Jackson
For last question:
I don't understand this line
w:=1000 given AR(w)=0 w0=FIND(w) w0=3509
1. Why do you use w:=1000 ?
2. Can you explain about Given ? I search about "Given" on help of MATHCAD but unfortunately i don't find any description of this!!!
3. Why evaluate sign "=" of AR(w)=0 bolder than other one?
4. Why in w0 before of zero (0) using "Decimal Point" sign?
Excuse me for my question, because i am newbie in MATHCAD
Your Sincerely
Saeid Jabbari
1. It's a guess value
2. Look up solve blocks in the help
3. It's a boolean equals, not a numeric assignment operator.
4. It's just part of the variable name. Look up literal subscripts.
