Hello all,
I'm in need to design a solution to prevent existing concrete surface to collect ice, when there is sparkling
water flying around. This is actually dam and the surfaces are the sides of it and dam is slightly leaking or
opened to let water run, so that there is lot of water drops everywhere.
Now I got idea to clean these concrete surfaces by high pressure water jets, glue RST-plate stripes side by side
using epoxy, and finally connect these plate to electric system to warm them max up to 30 deg. Celsius and
surrounding climate is below Zero.
The total area in question is ca. 30m2 per one dam and I have three dams.
My question is how to calculate the thickness of the plate, if they are f.ex. width=200 and length 5000
and what kind of current it might need??
Better off, if someone can give formula where these values could be calculated by myself? ;>)
Best Regards Matti Pitkanen
May be this (pics 18.8-18.12) will be a start pictures for you
You've got quite a problem. Actually, several of them.
It's going to be expensive!
Hi Matti,
I would use a so-called electric water heater, commonly used in homes where the gas network does not reach them, and with an electric pump, distribute hot water into a network of pipes or serpentine arranged on the walls where ice forms, a bit like you do to heat the floor. Heating with current could be dangerous.
Hi F.M.
Spraying hot water is no solution, due to large area and eccessive heat loss, I think.
Direct surface warming is much more effective, because it prevents the iceing on surface.
We have just now an other rebuild project where new vertically moving steel-made dam plate
ca. 5 x 4 m2 slides between U-shaped RST-made guides on both sides. These guides are
electrically heated. Me being a structural engineer, have no idea ( yet ) what is the
voltage, AC/DC-mode or current, but I have been told, that it is working well and can be made
for my idea too. ;>)
I have been asked to do preliminary design for cost estimate and budget, so I should know
with some accuracy the plate thickness.
BR Matti
You can calculate the resistance of a mild steel plate if you know the dimensions. So for voltage you can get current, etc.
Thanks Fred, now I can see some direction for my exams ;>)
How do you see my task: one big plate or several stripes ?
I'll come back next week, tomorrow in court as expert and week-end in Netherlands and back on Monday.
BR Matti
Trying to pass electricity directly thru structural steel seems to me to be difficult and risky. There would be many opportunities for unintentional current paths.
I suggest that you consult with a good electrical power engineer--sooner rather than later. If there's already a system in place that works, who designed and installed that?
Hi Matti,
I said to heat the surface with a conventional heating system. The heat conductive fluid , flowing in the appropriate pipes and radiator, could be high temperatur oil instead of water.
