Hello
In the attached file I would like to retrieve the result of the "qu" equation for use in the following calculations.
I don't know where to take it back or how?
Kind regards.
Denis
In Mathcad 11 I can do like this:
Chek out if you can do the same in Prime.
If not: the formula is simple enough to work it out yourself, because basically it's A=B*qu so qu=A/B.
Hello Luke
Thanks for your model in MathCad 11
But I would just like to be able to write "qu = 28.8 * 10 ^ 3" without having to assign the value to the variable "qu: = 28.8 * 10 ^ 3"
Kind regards.
Denis
Thanks Luke,.
I had not thought about it.
Actually it was just simple.
Kind regards.
Denis
