hello,
I installed MathCAD Prime 4.0, and my help file is English. I want to display another language help files.
It is better that display the help files of English and another language at the same time.
Tips:
How to change the web address parameters in address bar of web browser application, that i can read different help files at same time?
At least in P31 you could change the language that way:
MathCAD Prime Help is a web server in fact, so we can copy this web address "http://127.0.0.1:63532/index.jspx" into web explorer and press "ENTER Key", then you can open other help windows in web explorer and change the language, then we can have two language help window.
Usage: find what does a word mean in dutch:)![]()
Jeff Lee wrote:
MathCAD Prime Help is a web server in fact, so we can copy this web address "http://127.0.0.1:63532/index.jspx" into web explorer ...
Where did you get this link from? It does not work.
As we know, MathCAD Prime help files are based on the technology of Tomcat web server, if we want to open help in web browser, we should run MathCAD Prime help first because it is the server.
Obviously the port number (in case of your example 63532) is chosen at random.
You have to use the one you see in YOUR properties window as shown by Jeff.
