How to take the positive root for system of equations?
rskibba
2-Explorer
I need to solve the equations for X,Y and Z.  My current issue is I need a single equiation for each to solve the system.  What is happening is I end up with a  +/- solution due to the radical in the denominator.  So how do I get MathCAD to use just the positive value and solve for all three variables?
6 REPLIES 6
I hope You will understand why You have no solution
Valery,
Thanks for the response. OK I get it. I think the question I am really trying to answer is given the partial derivative of S on my attached script, How can I symbolically solve for X,Y, and Z?
Richard
LucMeekes
(To:rskibba)
With something like this:
rskibba
2-Explorer
(To:LucMeekes)
Luc,
Thanks for responding.  I tried that and basically it does not come back with an answer.  But if I solve just one of the variables X,Y, or Z.  It comes back with a +/- result.  This leads me to believe that the radical is causing problems. My goal is to come up with a general solution that I can use for a comparison.
Richard
Why do you need it?
LucMeekes
(To:rskibba)
You can't.
I'll demonstrate it on a simpler example. Given:
Please indicate the positive results for x, y and z.
