Hello , the problem is that because i have mathcad prime 4.0 but the problem is that i dont have the converter. So i need is someone could convert for me please. I have a test and i need that file. The format is in xmcd and i need it on mcdx. Thanks !
If you have Prime 4, then you also have (the right to install and use) Mathcad 15, which is required for the conversion.
You can use the same license that you used for Prime 4, to license Mathcad 15.
Once installed, you should be able to convert your file from the menu option in Prime.
Picture better
Yes, i knew about that , but the problem is that appears transparent because i dont have mathcad 15 . Now i'm installing it so i think the problem was that . Thank you!
Ok i will try to install mathcad 15 right now . Thanks
Thank you guys. The problem was that i have no mathcad15 installed. I recently install it and works !! LucMeekes Valery Ochkov @WernerExinger
You can download trial version of latest Mathcad 15 M045 service release here: Thank You for Your Interest in PTC Mathcad 15 | PTC
