I want to be able to read a known number of multiple input values from one excel sheet and populate the corresponding multiple outputs in another worksheet Those outputs will be a mix of values and text. To do this I assume I need a programming loop. I have a complex worksheet but can someone show me how to do with this in principal with this simple example ?
G
As a start, as Alan has done, you need to set the Output range within the embedded Excel component. Then you can work from there.
