I am using MathCAD 15 version,
Creating one area inside the worksheet and working inside the area, I not able to insert the second area in the same area.
Now what i am doing is split the first area in to two parts and insert the area middle of this split areas.
Anyone having better idea helps me.
Thanks in advance
It is very interesting question!
You can MOVE new area in one Mathcad 15!
Nested areas are not supported. As Valery notes, it is possible to create a nested area by dragging one into another, but if you do so it's at your own risk. The worksheet may not work in future versions of Mathcad.
