On 5/25/2009 8:11:20 PM, cpcfreak wrote:
>Hi to all,
>Is anyone able to explain how
>to make an interactive 3D plot
>of a dome that will report
>volume of a dome as height
>varies? I'm using MathCAD
>6.0e.
>Regards,
>Justin
The answer could be that all mathcad worksheets are interactive, in the sense that you can parameterize your specific problem and have "interactive" answers depending on the "setup" parameters.
The notation for this kind of tasks that I see usual is using global assignaments for the "setup" variables anywhere wiht the identical assignation (tripe 😃 and let the user to changing the problems parameters.
This method is typical in mathcad and is very unusual in other programing langs (like maple, mathematica, matlab). Even they can emulate this mathcad feature is needed some kind of programation with the interface to obtain this functionality, natural in mathcad.
Other times, is enough that you highlight the assignations for your problem to make enough clear that varying this values all the problem is rewriting. This with only normal := assignments.
This is, for me, the aception of the "interactive" meaning in your request, and the usual (and easy) implementation in mathcad.
If you want an animation (as synonymous of interactive) you can read the mathcad help, but this isn't the usual technology within mathcad. For mathcad animations isn't a synonymous of interactive.
Alvaro.
