Interpolated Points with Sloped Ground
- 9 replies
- 1547 views
- Translate All
I have three stacked blocks with widths denoted as B1, B2, and B3. Each block is 4 feet high, and the bottom elevation of the lowest block is defined by BotEL.
The ground surface is represented by a set of known points with X and Y coordinates describing its sloping geometry.
For each block, I need to determine the coordinates of two intersection points with the ground surface. These are labeled a1 and b1 for the first block, a2 and b2 for the second, and so on.
The "a" points correspond to the vertical lines at the right edge of each block, where the X-coordinate aligns with the block’s right edge. The corresponding Y-coordinate must be interpolated from the ground profile at that X-location, The "b" points correspond to lines forming an angle θ (theta) with the ground as shown. A Mathcad and an image illustrating the problem are attached.
I appreciate any help!
