Interpolation in Matrix with 2 variable (m,n) input
Vivek
6-Contributor
I am doing a hydradynamic calucation in MathCAD, Now i need to get the right coefficient as a output from table of value (row and cloumn). the input for the interpolation is 2 variable each from cloumn 6 row..Please see the attachment for the better understanding
7 REPLIES 7
Your image is like empty ? it killed my box 3 times !!!
This kind of project requires a work sheet .
Is it possible to post the worksheet? When viewing your image my computer froze and I have to close my browser.
The image is to small to view also.
Mike
Have a look at the attached worksheet, I think this is what your after.
Where there are blank spaces in your data I have inserted as zero. The image has also been re-attached for clarity.
Mike
Vivek
6-Contributor
(To:MikeArmstrong)
Thank yor verymuch... it worked excellent..
You could edit your original post for the purpose of removing the image that did crash at least Mike and myself.
A more complete tool attached Mathcad 11.
jmG
Vivek
6-Contributor
(To:jeanGiraud)
Thank you.. I have updated the attachement....
Thats better .
If the question has been answered you can indicate by selecting "correct answer" on the post which answered the original question - helps other collabs when trawlling through posts.
Mike
