Hi, Is it possible to do in Mathcad Prime an interactive template with action buttons (or if is possible if someone can share a sample template) where there could be a large set of formulae connected one after the other for specific types of scenarios. I would only go and click these action buttons and the formulae I need will be the ones displayed,
I want to know if I can insert like an "action button" and be directed to the formulae I need. Is this possible in Mathcad prime? thanks
I am not sure what kind of functionality you are looking for exactly, but I guess if possible, it could be implemented only in Mathcad 15 and below using hyperlinks and/or controls and scripted components.
Prime is very limited and all those features are not available in Prime.
What I could think of in Prime is to assign a variable at the top of the speed and make all calculations dependent on this variable so you get the appropriate results. In real Mathcad you could implement this via push buttons, radio buttons,check boxes, dropdown lists,etc.
