Is it possible to use lsolve for vector unknows
ifomenko
I try to use lsolve to find coordinates of unknown Bezier control points. But mathcad 15 doesn`t like vector v which consists of vector values.
Does it means that I need to solve system for each component of point coordinate,i.e. one time for x and one more time for y?
Did you try "vectorizing" the function (putting the arrow above?)
Thank you very much Fred. You are genius
All is OK,but,vectorizing is working only for symbolic engine in this case.So I have to transform vector b of Ax=b to two column matrix (first column for X coordinates and second - for Y).
In this case it`s not necessary to use vectorization at all.Please see attachment.
