Keying in Symbolics into a Program
ptc-4310378
Am trying to duplicate a program written by WE in discussion http://communities.ptc.com/message/178339, to include Symbolics into a Program, but am not clear about the keying sequence, please see attached.
Thanks.
RichardJ
(To:ptc-4310378)
OK. I see. What you want to do will work fine. You can even delete the second line of your program (the "A").
6 REPLIES 6
RichardJ
(To:ptc-4310378)
You can't key it in because the structure is not allowed. Symbolic evaluations are not allowed within programs. They were allowed in version 11 and earlier, but not any more. Even then, the only way to create them was cut and paste.
Thanks for the bad news.......
Strange enough, it seems to be working for this one "Symbolic Only" Ei function (attached), using the cut&paste method....Are there any exceptions to the "Not Allowed" rule?
Do you see any downside using the program as is?
Thank you.
RichardJ
(To:ptc-4310378)
I am a little surprised it lets you do that. So it seems you can evaluate a symbolic expression inside a program, but you cannot subsequently use the result of that evaluation in the program (which arguably makes it pointless evaluating it in the first place!). Inn the attached worksheet the last two programs work in MC11, but not in later versions.
Am running the Ei Symbolic Function through the program to be able to define it at a function that can be used in another function, as I don't know how to do that using its original Symbolics format only. So the lack of further usefulness within a program shouldn't be detrimental for this purpose?
Thanks again.
RichardJ
(To:ptc-4310378)
Not much of a surprise after your attached examples of failed programs, but this "programmed" function doesn't want to be called either!
I guess I will try to look at interpolating on a curve fit over the range of interest.
Thanks for the help. Saved me from wasting too much time on that.
PS: The Ei function is not available in 2001.......
