Logarithmic Histogram
MoeSzyslak
All --
I am attempting to fit a lognormal distribution to a histogram with logarithmically-spaced bins, but am not having much luck. I suspect that at least part of my problem is the old "linear fit, logarithmic plot" problem, but I can't seem to shake it this time. Any ideas?
As always, thanks in advance....
Matt
5 REPLIES 5
On 4/9/2010 12:33:33 AM, Moe_Szyslak wrote:
>All --
>histogram with
>advance....
>Matt
_____________________________
Your Z vector is now raw data, too many 0 values or near zero. If it would be from collection, then the ratio of the max to the min indicates a very poor collection. I don't understand your fabrication. You must test the data first and as you can see the histogram is not lognorm.
You could probably fit several distributions to that histogram
jmG
RichardJ
(To:MoeSzyslak)
It doesn't matter what the x-spacing is. Minerr just minimizes the y-residuals.
Dividing y in the solve block by a negative number does not help 😉
Richard
It could be that the original data are paired.
It would enable a weighted histogram "Paul style".
w/o the raw data = end of project.
jmG
>data are paired.
>project.
>jmG
______________________________
An extraordinary good Gaussian fit,
that puts me out of a context w/o context.
jmG
Richard, Jean --
Thanks so much for the help -- sometimes I can be a little dense.
Matt
