Logfit Problem
Raiko
Logfit Problem
hello folks,
I fail to find the cause of my problem.
When fitting a function to measurement data, the continuous version; i.e. with x a dependent variable, it works like a charm. when I try the same piecewise; i.e. with the values from the data set, all but the last value are zero. Any clue to the whys and whats?
Raiko
P.S.
As always, MC15 on win7 on a 64 bit machine
Hi Raiko,
You forgot to define the range variable.
Andy
Hi Raiko,
Andy
FIRM SLAPPING OF THE FOREHEAD WHILST TYPING WITH THE OTHER HAND
Thank you Andy, I knew it was me 😉
