My question is similar to that asked here but not quite:
http://communities.ptc.com/message/187420#187420
I am writing VBA macro to get a value from a MATHCAD worksheet using the OLE object interface with the getValue method.
My question is, is it possible to get variables with literal subscript names. That is, if I had a statement like:
x.1 := 1
how would I use the getValue method to retrieve the value of x.1?
getValue("x.1") does not work however if I ditch the subscript the method works fine. I am hoping there is a simple trick or work around so I dont have to redefine my variables.
Appreciate your help.
Regards Jacob
