Is there a way to recover a lost MathCAD 13 Product Code. I have located my CD & Box, but have been unable to locate the original CD Envelope with as I understand it has the Product Code on the back.
David Cole
Hi David
If is your MathCad Rev 13.0 I can help?!? for 32-bit only
I have similar problem my CD is damaged!
Regards
John
For both of you, please log your issue at https://www.ptc.com/appserver/cs/mathcad_case_logger/options.jsp
Someone should be able to help you.
Mona
