MathCad copied to Word
pposton
Hi All,
Recently we starting using MathCad.  Our team made several math calculations in MathCad.  Then we selected all the calculations and copied then pasted them into a Word document as a image.  Part of the image was cut off (we are not sure why).  Is there a better way to import MathCad calculations to Word?  Thank You in advance for any help. FTC Team 5326
StuartBruff
(To:pposton)
Which version of Mathcad are you using,  eg Mathcad 15 or Prime 3.1? Can you post an example?
Try pasting the calculations into Paint and seeing if you get the same cutoff.
If you're trying to put all of the calculations into Word,  downshift upon what you want,  you could print to pdf o Rd xps and pick out what you need from that.
Stuart
Hi Stuart,
I am using MathCad Prime 3.1 and Word 2007.
Oh thank you.  I just tried copy it and pasting it into Irfanview (I have that instead of Paint).  It worked perfectly!  Thank you for your help.
Patti
FTC Team 5326
And loving MathCad now!
Patti,
in Windows 7 you can use Snipping Tool to put selected part of the screen into Clipboard and the paste it into Word document.
MH
Martin Hanák
