It's my first post so I would be thankfull if someone could help me
I'm using mathcad 15
My question is when im adding component such as excel there are inputs and outputs... what's that? :[
is there any way that when i defined some stuff such as: c.bp=281 ; c.zp4=333 ; c.zp5=316 etc. the result of the each equation it will be in excel in different cells?
if it's impossible then let's say I put on excel everyhing by myself... and I want to get QW = "number" where "number" is the 1454,18 and it's on the cell D7 in excel.... somehow mathcad will read that from excel... a bit complicated but I hope you can understand me and my weird english
Greetings,
Launch mathcad help, search for "excel", and read about the component.
Then look at the example.
I'm sure it i possible. Can you provide a worksheet with an example? Maybe with the expected results you want to see.
Mike
