Mathcad Basics - Problems
TudorMarin
You are now ready to try some problems on your own. In all Problem sections, you will work out problems so that you can test your new abilities with Mathcad. There are only two problems in this section.
Remember, Mathcad allows you to organize the problem after you have the solution. Start out by experimenting with a few calculations to get an understanding of the problem, but then go back and include some text to explain your thought process and discuss the answer.
Always double-check to see if the answer you are getting seems reasonable. Mathcad may know how to do math, but that does not mean it is good at reasoning.
0 REPLIES 0
