Mathcad Prime 8 - Page breaks don't work with multi-page areas?
PEAH
Hi everyone
Mathcad Prime 8's page breaks apparently don't work properly with multi-page areas.
I have two areas where the first area is two pages long. If I add a page break after the first area, the third area appears correctly on page 3. However, if I collapse the first area, the third area still appears on page 3, but should have appeared on page 2.
The work-around appears to be to add an element (e.g. a text region with a space) after the first area and before the page break - then collapsing/expanding areas don't mess up the page break.
Has anyone seen this before?
PEAH
(To:PEAH)
This is apparently related to the following knowledgebase article from Prime 7, however, that article does not provide any work-around:
https://www.ptc.com/en/support/article/CS363369?oskarSession=6e83132b-6cd4-49a1-a14c-7ee34c9ef160&source=support_assistant
