Is it possible for Mathcad Prime to integrate a piece wise function? In the attached worksheet I am attempting to integrate a piece-wise function 4 times. If possible I'd like to be able to create a graph of these functions and then pull values from the graph.
The graphing error may stem from the fact that you define x from -1ft to ... , but the definition of w(x) is for values of x from 0ft to l.
the function itself is very discontinuous & this may lead to failure to integrate or numerical errors due to rounding and/or aliasing.
In the attachment, a simplified function will integrate, but returns 0.
regards
Andy
Sorry. It's a Mathcad 3.1 file, and Mathcad 3.0 (which is what I have) can't read it. You also can't save it back to version 3.0. Amazing, but true.
Please find in attachment PDF and XPS version of this worksheet.
regards
Andy
