Mathcad Pro/E integration
dm-3
I have a spring calculation done in Mathcad 15.0. I am integrating the results with Pro/E wildfire 5.0 for creating the spring model.
I try to create a variant from the part file by creating a back-up from the created partt file and changing the input values, adding further more calculations to the existing sheet.
If I do this the relations are getting distorted. I get a warning that relations is having errors.
How to correct this?
Dhinesh
VladimirN
(To:dm-3)
Hello!
...If I do this the relations are getting distorted. I get a warning that relations is having errors...
Could you show a screenshot of this error?
dm-3
(To:VladimirN)
Vladimir,
Find the attached screen shot.
Dhinesh
VladimirN
(To:dm-3)
You used tags for data transmission "mc2proe" and "proe2mc", but just forgot to specify also near to value and units of measure in Mathcad! Without them integration will not work.
