Mathcad Program learn
JaydeepPanchal
Hello All,
This is Jaydeep again.
I am attaching the mathcad file that can applicable to gear manufacturing. I am working on that and stuck at one place. In that I need your appreciable help.
There are equations for SB, SB1, SS, and BHNW. These equations are inter-conected with facewidth.
Facewidth is shown in the mathcad fine.
I created one additional equation of U(Pitch) to understand my problem properly.
I wanted to multiply each and every values of U(Pitch) with single value of facewidth values one by one.
I also gave one example in mathcad file so you can understand what I want is.
Please See the Mathcad Program to understand exactly about my problem.
Thank You.
Jaydeep.
9 REPLIES 9
Hey All,
Does anyone help me here ..??
Did you understand what I am asking ?
Please let me know.
Thank you.
Jaydeep.
Is this what you are looking for?
Hey Wayne,
Ya I was talking about that. Thank you for your help but I solved it before you posted reply.
Now stuck with another problem.
Anyway appreciate for your help.
Jaydeep
Hello Wayne,
See the attachement to find out what is my new problem is and where I am stuck. I think you can help me on this.
I wrote the comment please see it.
Thank you.
Jaydeep
Jaydeep Panchal wrote:
...I wrote the comment please see it...
Where they are in your worksheet?
Yes that's in the workesheet.
Jaydeep
Jadeep,
I added a few things, but note that the [19,1] are nested vectors (19 columns, 1 row), and not a number. So if you expect a number, you have an error above. Also recommend that you use i=1..rows(matrix)-1 rather than specifying a number, more general.
I got this also before but I wanted to get number insted of [19,1]. Is there any possiblity to get that?
Jaydeep,
Each element of the SSall matrix is not a number, it is a vector of values. The following is the 0,0 element:
Do all of these values apply? If you only need the maximum, you can add max to the program. Otherwise, I don't know what you need. (all the values are positive, if negative values are possible, then you need to revise accordingly.)
