can someone convert this file. Need to read the formulas inside this file.
Just installed mathcad with 30 day licens.
Thanks.
Its not a limitation of the student edition of Prime.
To be able to convert files from legacy format to Prime format you must have a full version of Mathcad 15 installed on your machine. Mathcad 15 will happily run if you point it to the license file you created when you installed Prime.
You can download Mathcad 15 here:
https://www.ptc.com/en/products/mathcad/free-trial/thank-you
http://download.ptc.com/products/mathcad/trial/mc15/Mathcad15_EN.zip
https://www.ptc.com/-/media/Files/Docs/Mathcad/Mathcad15-EN.zip
I can't do the conversion for you as I don't have Prime 3 installed and newer versions of prime can't save in older versions format and so your prime 3 would not be able to open the file I converted.
