Mathcad fails to solve symbolic system of equations and put it in a function!
- February 14, 2019
- 4 replies
- 4906 views
Hello.
Before anything, I got to say that I searched the whole forum for similar questions (which existed), and tried to apply them to my case, but none worked!
I attached files (one is Mathcad15 and the other is Prime 5 file format) with system of equations that I need to solve symbolically, and then attribute this solution to a function.
The system of equations has x's, a's, z's and a y variable. The goal is to define y as a function of x's and a's, but no z's.
I failed to do it multiple times: sometimes Mathcad just crashs, other times it just says some variables are not defined...
Could someone please help me? This is the first thing I'm ever trying to do using Mathcad!
Thank you very much!
